Gs350 awd rim size!! Help me!
Old 02-16-12, 06:47 AM
seanyoon
seanyoon's Avatar
Default Gs350 awd rim size!! Help me!
I have 245/35/20 and 275/30/20 if i use only summer is this ok for my gs?
Old 02-16-12, 08:39 AM
DidItOnEm
DidItOnEm's Avatar
No good at all! The rolling diameters are way off. Your gonna have to do some research on the tire sizes. Go to 1010tires.com you will be able to put in different tire sizes that would get you close to the stock RD.
Old 02-16-12, 09:43 AM
Kcook700
Kcook700's Avatar
I have the same car and running 245/30/20x9 and 285/25/20x10.5. I believe that is the recommended size for my rims.
Old 02-16-12, 10:18 AM
IXI187IXI
IXI187IXI's Avatar
245/35 is too big for the AWD. you must keep the overall diameters within 2% of the stock diameter to avoid damage to the AWD system (at least told to me by a lexus tech)
Old 02-16-12, 10:23 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
actually if front and rear got bigger together but close to each other, it's fine. again the car has no way of knowing what overall diameter you using. key is to match front and rear diameter closely, not necessarily matching factory diameter
ideally you want 245/35/20 and 285/30/20, that's overall 1" larger in diameter both front and rear from stock. but good luck dealing with all the rubbing issues
personally i would still recommend 245/30/20 and 285/25/20
Old 02-16-12, 11:07 AM
seanyoon
seanyoon's Avatar
Now i have tsw 255/3519 all around. I want some big rims for rear.. So its not good for awd with that size--245/35/20 and 275/30/20?
Old 02-16-12, 11:41 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
your post is confusing. you want some bigger rims (20) for just the rear?!
Old 02-16-12, 01:55 PM
seanyoon
seanyoon's Avatar
Yes i want big rim for rear
Old 02-17-12, 01:36 PM
gridlock13
gridlock13's Avatar
do you mean WIDER rims?
Ravishah89
10-05-15 04:03 PM
seanyoon
Suspension
05-15-12 12:49 PM
seanyoon
03-14-12 11:40 AM
seanyoon
01-01-12 03:42 PM
clubrph
01-10-09 06:30 PM
Quick Reply: Gs350 awd rim size!! Help me!
