2006 GS300 Rotor Dimensions
Old 01-04-12, 10:01 AM
Tres
Tres's Avatar
Question 2006 GS300 Rotor Dimensions
As always, I apologize if this is somewhere else in the forums but I’ve looked for a while and found nothing.
Anyway, what are the specs for rotors for my 06 GS300? The plan was to have new ones on hand when I do my brake job and measure the rotors when I get the tires off. If they’re already too low then I’ll just replace them right there. If not, then I’ll just return the new rotors. I can use calipers to measure the rotors but I need to know the min/max dims, etc.
Thanks for the help!
Old 01-04-12, 12:21 PM
TWong350
TWong350's Avatar
The values should be on the rotor itself. Might be a little dirty and hard to see but it's there. In any case, here are the specs from the manual.
Standard thickness: 32.0 mm (1.260 in.)
Minimum thickness : 30.0 mm ( 1.181 in.)
Make sure you have an accurate micrometer or dial calipers!
Old 01-04-12, 12:29 PM
IXI187IXI
IXI187IXI's Avatar
also if you order new rotors, there is a difference between AWD and RWD rotors.
Old 01-04-12, 12:52 PM
TWong350
TWong350's Avatar
Yes, good point. The info I provided is for RWD
Old 01-04-12, 12:58 PM
Tres
Tres's Avatar
Great, thanks Wong.
and IXI, I found tht out when I did the front brakes, but thank you for the warning as well.
Looks liek the hard part will be getting a new caliper.
sakon3
17
06-11-20 02:17 PM
HarrierRX300
01-27-13 10:48 PM
LexLuger06
08-28-12 07:42 PM
weesped
Suspension and Brakes
11-17-07 08:24 PM
Quick Reply: 2006 GS300 Rotor Dimensions
