Wheel Alignment
Old 07-12-11, 02:53 PM
cherrypik
cherrypik's Avatar
Default Wheel Alignment
I just had my tires rotated at Costco and the rep said that the inner tires are wearing more then the outer tires and I should get wheel alignment. Does it matter if I go to either NTB or Firestone instead of the dealer?
Old 07-12-11, 03:42 PM
Brian@Vossen
Former Sponsor
Brian@Vossen's Avatar
Once they have top techs and a good alignment machine (Hunter) it should work out. Make sure the camber is correct as well.
Old 07-12-11, 04:07 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
tech and machines are key, not the shop name (dealerships or local shops). correcting camber is important, but toe is probably just as crucial
Old 07-12-11, 04:41 PM
Brian@Vossen
Former Sponsor
Totally forgot about toe Yup you are right.
Old 07-13-11, 08:20 AM
cherrypik
cherrypik's Avatar
Thanks guys!
Well I guess I have a dilemma. I took it to a well know alignment place in IL right after I purchased my new tires from Costco about 1.5 years ago. Now I have the same problem I had then before I purchased new tires. My tires are again cupping due to the inner tire wear. Is it too late for a wheel alignment?
Old 07-13-11, 08:48 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
well of course on this set of tires it might not last as long, but it will help
Vpanin
10-18-10 04:26 AM
aznpapaya
12-21-09 07:03 AM
MarcusMIA
SC- 1st Gen (1992-2000)
10-14-09 07:08 PM
hoonami
01-13-09 06:44 AM
Quick Reply: Wheel Alignment
