flat tire means new tires??
Old 01-23-11, 08:59 PM
LIMS407
LIMS407's Avatar
Default flat tire means new tires??
if check tire pressure light still on after filling all the air, is it mean i might have issue with sensor or tires?? almost died today because of flat tire on the highway,,,
Old 01-23-11, 09:17 PM
passnu2
passnu2's Avatar
my guess would be a nail in your tire.
Old 01-23-11, 09:58 PM
msgs350
msgs350's Avatar
If you had a bad sensor, i think it would say TPMS not detected. I had 1 sensor that failed once and it had a different message ( not 'low tire" that i think you are seeing). I went to Discount Tire and they had a hadheld unit that re-synced it.
Old 01-24-11, 06:10 AM
BinaryJay
BinaryJay's Avatar
If the car can't find one of the TPMS sensors due to it being defective, dead battery, or not registered to the car the message will be "CHECK SYSTEM" with the TPMS light on the dash lit and a flashing exclamation mark.
Old 01-24-11, 07:07 AM
OhOneWS6
OhOneWS6's Avatar
Sometimes you have to go above the recommended pressure by a few pounds to get the sensor to reset. Once it resets you can let the pressure back down to the recommended level.
Old 01-24-11, 06:06 PM
LIMS407
LIMS407's Avatar
took the tire off today and saw the big bubble on my tire,,,dont know if tire is bad or what,,,did some research on my pirelli but didnt find anything,,,
Old 01-24-11, 06:36 PM
OhOneWS6
OhOneWS6's Avatar
Time for a new tire. Here is an article about it.
http://www.tirerack.com/tires/tirete...urrentpage=187
Old 01-24-11, 07:07 PM
LIMS407
LIMS407's Avatar
thanks,,
gebo
GX - 1st Gen (2004-2009)
09-23-18 05:56 AM
Kuhn
11-27-17 10:43 AM
Damage
IS F (2008-2014)
03-31-17 01:23 PM
Sofaires
02-06-14 10:01 AM
Fuzzie
03-30-10 11:46 PM
Quick Reply: flat tire means new tires??
