gs350 valve spring recall
Old 06-13-12, 08:44 PM
  #31
AlDavison
AlDavison's Avatar
Unhappy Gas Milage Dropped
I got this recall done and my gas milage drop to 19 mpg. Is this normal because some time I fill-up twice a week.
This was not the case before.
Old 09-22-21, 08:06 PM
  #32
User 122922
User 122922's Avatar
I’m very glad you mentioned this, I purchased an 08 Lexus GS 350 with 113mi, I know it’s been along time since you posted this, but I have problem now my car has a white/bluish puff smoke comes at startup when the car is warmed up only, and it disappear within 5-6 second, it doesn’t happened everytime but it does happened often, what you think this is could be ? I’m glad I found someone working at Lexus as a tech. Thanks 🙏
Originally Posted by Tmoriarty
so i work for lexus as a tech and have done multiple IS350 and GS350 spring recalls. i dont own one but from doing multiple recalls and hundreds more to come i would gladly hand my keys to the dealership as ive noticed lots of negative talk about it. it is a big job, we replace the springs with heavy duty springs, replace the hydraulic lifters with new ones and all the gaskets and seals. the valve spring kit alone costs 1500$ every one that i have done has had noticably better acceleration, increased throttle response and all around more power. besides the fact that as techs we get screwed by only getting paid 7 hrs for the whole job that takes 11-14 depending on the tech i think as a customer you should be thrilled. as long as the tech doesnt make a mistake and damage something, which even if that did happen lexus or the dealership would have to cover the mistake. the worst part of the recall is trying to set up the cam chains. the timing is very tricky. swaping the springs with the special tools is a breeze
MWIS350
05-26-15 03:19 PM
Todd Edge
11-13-11 02:43 PM
Cut-Throat
04-12-11 10:52 PM
Tmoriarty
10-10-10 04:36 AM
Tmoriarty
09-27-10 08:06 AM
Quick Reply: gs350 valve spring recall
