List of TSIB (Recalls/Campaigns) for 3GS
Old 03-02-11, 04:00 AM
IXI187IXI
IXI187IXI's Avatar
Originally Posted by bhuwan
This is great stuff. I do hae a question: how do you approach the dealer to apply some of these TSIB's? Do people just ask?
if your car is still under the factory warranty (4yrs/50k) then yes, just bring in whatever tsb you have, shown them and say you would like this fixed.
Old 03-02-11, 05:03 AM
BinaryJay
BinaryJay's Avatar
It might go down easier if you just go in and explain you have a problem in the same wording as the TSB uses and give them a chance to find it and offer it - otherwise, they may look at your problem with more skepticism than usual.
Old 03-02-11, 06:49 AM
MadDawg350
MadDawg350's Avatar
**** MODS ****
Please make this thread a sticky. A lot of great info here that should be made so that it is easily found for those who may be looking.
Old 03-09-11, 07:50 AM
mydawgz
mydawgz's Avatar
I just got an email this morning with the following information on a new recall.
A safety recall has been issued for your 2006 Lexus GS 300:
Dealers will modify the plastic pad on the floor carpet free of charge. the manufacturer has not yet provided an owner notification schedule. owners may contact toyota at 1-800-331-4331
I am not sure what this one is all about, but I guess we will find out.
Bev
Old 03-09-11, 07:52 AM
bhuwan
bhuwan's Avatar
Bev
From lexuslink :
2006 LEXUS GS300
Safety Recall BLB - 2006 - Early 2007 Model Year GS 300 and GS 350 AWD Vehicles Plastic Pad Embedded into the Floor Carpet
This is an important Safety Recall. Please contact your authorized Lexus dealer and schedule an appointment to have this remedy performed as soon as possible.
What is the Condition?
In 2006 through early 2007 model year GS300 and GS350 AWD vehicles, in the event that the floor carpet around the accelerator pedal is not properly reinstalled in the correct position after a service operation, there is a possibility that the Plastic Pad embedded into the floor carpet may interfere with the operation of the accelerator pedal arm. If this occurs, the accelerator pedal could temporarily become stuck in a partially depressed position rather than return to the idle position. An accelerator pedal temporarily stuck in a partially depressed position may increase the risk of a crash.
Old 03-23-11, 08:29 AM
THE.K.W.C
THE.K.W.C's Avatar
how do I know which are recalls???
Old 03-23-11, 02:28 PM
Evel
Evel's Avatar
New Safety Recall for 2006-07 GS300/GS350's:
Just received a new Safety Recall Notice by mail today. This one is titled "Insufficient Tightening of the Fuel Pressure Sendor". If loose, it could allow fuel to leak past a gasket used in connection between sensor & pipe & through the threaded portion of the sensor. If this is the case, the gasket between the sensor & fuel delivery pipe will be replaced & the sensor tightened with the proper torque. Symption of this issue is smelling gas in the engine compartment.
If not found loose, dealer svc will tighten the fuel pressure sensor with the proper torque.
Will take it to nearby Lexus dealer tomorrow to be checked out. They made a point to inform that you still need to have this checked out even if you've already had the fuel delivery pipes (aka fuel rails) replaced under a different Safety Recall/TSB...which I had performed last year.
Old 04-18-11, 08:32 PM
spygirl08
spygirl08's Avatar
Can you post CRIB167 JUL 08 Body/Interior - Trim Removal & Installation
Thank you..
Old 07-23-11, 07:15 PM
Brunogs430
Brunogs430's Avatar
Default 2006 lexus gs 430 water leak? in passanger front and rear seat
Does anyone out there have a fix to this problem , i have worked on it for 2 days looking for this drain tubing that is blocked and spoke to all kinds of service advisory(s) on a wild goose chase. Where can i find the Tsib for this make and model in canada and usa
Originally Posted by charmz
This is a list for 06 GS300 AWD, but im sure at least some must also apply to the 350's and RWD models.
Thought this might be useful to some people? Maybe it would be helpful if anyone has the pdf's to any of these to post them in this thread and make it a sticky possibly?
Edit: Thanks to TWong1200 for stepping it up for everyone here! BUT if you do recieve a TSIB from him PLZ UPLOAD IT IN THIS THREAD like I have done below so his inbox is not flooded with constant requests.
TSB Number & Issue Date - TSB Title
SSC9LA JAN 09 Recall - Fuel Rail Replacement
SSC7LC NOV 07 Recall - Fuel Pipe Replacement
SSC6LC APR 06 Recall - Front Seat Belt Retractor Replacement
SSC6LB APR 06 Recall - Side/Knee Air Bag Replacement
SSC9LC JAN 09 Campaign - EPS Steering Gear Replacement
SSC9LB JAN 09 Campaign - Rear Brake Caliper Inspection
SSC6LE JUL 06 Campaign - Electric Power Steering (EPS) Replacement
SB0188-09 DEC 09 Engine Controls - A/F And O2 Sensor Identification
SB0168-09 NOV 09 Fuel System - MIL ON/DTC's P0441/P0455/P0456
SB0085-08R1 OCT 09 Engine - Serial Number Locations/Identification
SB0084-08R1 OCT 09 A/T Serial Number Identification/Locations
SB0153-08R1 OCT 09 A/T - Reman A/T Serial Number Location/Identification
SB0092-09 AUG 09 Engine Controls - MIL ON/Multiple DTCs Set
SB0090-09 AUG 09 Audio System - Satellite Radio Inop Until Ign. Is Cycled
SB0076-09 JUL 09 Engine Controls - MIL ON/DTC's P0751/P 2714/P0894
SB0154-08R1 MAY 09 Tires - Pressure Compensation/Adjustment
CRIB173 APR 09 Paint - Refinishing Information
SB0025-09 MAR 09 Tire Monitor System - 'Lost Communication With ECU'
SB0023-09 MAR 09 A/T - Fluid Level Inspection/Temperature Ranges
CRIB172 MAR 09 Body - Bumper Component Repair
SB0011-09 FEB 09 A/C - Intermittent Unpleasant Odors
SB0001-09 JAN 09 Body - Moonroof Auto-Close Function Inoperative
SB0174-08 DEC 08 Steering/Suspension - Vehicle Pull Repair Supplement
SB0152-08 OCT 08 Engine - Brief Knock/Rattle On Cold Start Up
SB0125-08 OCT 08 Cruise Control - Check PCS Message/DTC B2056/P1572
CRIB170 OCT 08 Body - Plastic Bumper Refinishing
SB0123-08 OCT 08 Body - Trunk Won't Open Electrically/DTC B2216 Set
SB0120-08 SEP 08 Body - Fuel Door Loose/Difficult To Close
SB0091-08R SEP 08 Engine - Valve Timing Procedure
SB0090-08 SEP 08 Body - Upper/Lower Windshield Tick Noise
SB0087-08 SEP 08 Engine - MIL ON/DTC's P0300 - P0306 Set
CRIB164 SEP 08 Vehicle - Replacement VIN Plates/Certification Labels
SB0083-08 AUG 08 Body/Frame - Protective Wax Coating Information
SB0047-08 JUL 08 Lighting - HID Headlamp Diagnostic Tips
SB0040-08 JUL 08 Interior - Instrument Panel Rattle
SB0038-08 JUL 08 Interior - B-Pillar Lower Moulding Scratched/Gouged
SB0036-08 JUN 08 Keyless Entry - Smart Key Battery Diagnostics
SB0031-08 JUN 08 A/C - Interior (Cabin) Filter Replacement
SB0026-08 MAY 08 A/T, M/T - Alignment Pin Service Precaution
SB0024-08 APR 08 Brakes - Rattle From Vehicle Rear on Bumps
SB0021-08 APR 08 Engine - Cylinder Head Cover Baffle Precautions
SB0015-08 MAR 08 ABS/TCS - Zero Point Calibration Information
CRIB165 MAR 08 Body - Acid Rain Paint Damage Prevention/Repair
AC003R-07 FEB 08 A/C - Driver/Passenger Front/Rear Carpets Wet
CRIB162 FEB 08 Body - Quarter Panel Service Part Modification
CRIB163 FEB 08 Body/Frame - Sealing Hem-Flanges & Body Seams
CRIB161 JAN 08 Body/Frame - Collision Damage Repair Precautions
CRIB160 DEC 07 Restraints - SRS Service Precations
PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
CRIB158 OCT 07 Body/Frame - Panel Adhesive Information
SS006-07 AUG 07 Electrical - Absorbed Glass Mat (AGM Battery Info
SS005-07 AUG 07 Restraints - SRS Component Disposal
CRIB155 AUG 07 Body/Frame - Sectioning Guidelines
CRIB156 AUG 07 Electrical - SRS and HV Wiring Repairs
TC008-07 JUN 07 A/T - 'World Standard' Fluid Information
EG015-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor Identification
NV007-07 JUN 07 Interior - Inside Mirror Vibrates
BO006R-06 MAY 07 Body - Rear Power Sunshade Won't Open Fully
PG001-07 MAR 07 Tire Monitor System - Diagnostic Tips
EG003-07 MAR 07 Cooling System - Leaks From Water Outlet Assembly
EL001R-06 MAR 07 Smart Key(R) - Repair Manual Supplement
TC002-07 MAR 07 Drivetrain - Driveshaft Replacement Precautions
EG001-07 FEB 07 Engine - Timing Cover/Camshaft Housing OIl Leaks
EL002-07 FEB 07 Air Bag System - Repair Manual Supplement
EL016-06 DEC 06 Starting System - Vehicle Start After Battery Depletion
EL015-06 DEC 06 'Smart Key' (R) - Specifications
PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles
SU001-06 OCT 06 Suspension - Shock Absorber Replacement Criteria
EG014-06 JUN 06 Emissions - MIL ON/DTC's P043E/P043F/P2401/P2402/
AU001R-05 JUN 06 Audio System - Dash Speaker Connector Rattles
NV001-06 MAY 06 Interior - Front Seat Squeaking Noise
EG011-06 MAY 06 Exhaust System - Excessive Sulfur Odors
AX001-06 MAY 06 Audio System - SIRIUS(R) Radio Antenna Separation
AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide
EG006-06 MAR 06 Engine Lubrication - ILSAC GF-4 Oil Recommendation
BO002R-06 MAR 06 Body/Lighting - Headlamp Support Bracket Installation
PD023-06 MAR 06 Parking Assist System - Initialization Procedure
EG001R-06 JAN 06 Engine - ILSAC GF-4 Engine Oil Standard
BO001-06 JAN 06 Body - Trunk Will Not Close
SS003-05 NOV 05 Audio System - CD Player Skip Verification
EG020-05 NOV 05 Engine Controls - MIL ON/DTC's P0171/P0174/P02195/
BO012-05 NOV 05 Interior/SRS - Seat Cover Replacement
BO010-05 OCT 05 Restraints - Seat Belt Extenders Available
CRIB150 OCT 05 Paint - Paint Codes
BO008-05 SEP 05 Body - Left Rear Door Lock Difficult to Operate
NV002-05 SEP 05 Body - Creaking Noise from Back Glass Area
SS005R-01 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function
BO007-05 AUG 05 Interior - Glove Box Doesn't Open
BO006-05 AUG 05 Interior/Lighting - Dome Lamp Comes Loose
TC003-05 AUG 05 A/T - A760H Solenoid Identification
PG007-05 AUG 05 Tire Pressure Monitor - Sensor Registration/Initializing
PG005-05 JUL 05 Tire Monitor System - Tire Dismounting Procedures
BO004-05 JUL 05 Wipers/Washers - Wiper Blade Cleaning/Maintenance
EG012R-04 JUN 05 Engine Controls - Entering VIN After PCM Replacement
SU001-05 JUN 05 Suspension - Creaking Noise From Front Suspension
EL006-05 MAY 05 Electrical - Vehicle Start After Battery Depletion
BO003-05 APR 05 Restraints - Seat Belt Extender Availability
PD008-05 FEB 05 Tire Pressure Monitor - Sensor Activation
PD007-05 JAN 05 Body - Power Window Initialization Procedure
PD003-05 JAN 05 Body - Sliding Roof Initialization Procedure
PD004-05 JAN 05 Interior - Driver's Head Restraint Initialization
PD001-05 JAN 05 Instruments - Compass Calibration Procedure
Old 10-28-11, 04:53 PM
spwolf
spwolf's Avatar
https://docs.google.com/viewer?a=v&q...xoKTKSoyr12Alw
drain tube fix - L-SB-0016-10.
Old 10-28-11, 05:01 PM
spwolf
spwolf's Avatar
i decided to post all of the related threads for GS300/350 water leakage and damp carpets due to drainage pipe being blocked.
File Type: pdf
Old 10-28-11, 05:07 PM
toptech
toptech's Avatar
well, i have the PDF's for all of these, if you really want the PDF for one let me know. i dont want to post them all here. i guess one day i might but it is copywritten material.
Old 10-29-11, 12:54 AM
GS350Lexus
GS350Lexus's Avatar
Originally Posted by toptech
well, i have the pdf's for all of these, if you really want the pdf for one let me know. I dont want to post them all here. I guess one day i might but it is copywritten material.
do it!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 05-30-12, 09:43 PM
sdjones
sdjones's Avatar
My wife's 06 gs300 had water in the passenger front, rear, and driver's side read floor. I found out about a rubber grommet that seemed to be causing a blockage, so i decided to take a shot at removing it per the TSB since the vehicle is no longer under warranty.
I just removed the evaporator drain grommet and I didn't need to unhook the exhaust or lower the transmission, even though the TSB says that's the procedure. I jacked up the car and bent the exhaust shield a little, and was able to reach the drain (though i couldn't see it) from the driver's side of the transmission. I though it would be a tougher, but it wasn't too bad; only a few scrapes from squeezing my forearm between the transmission and exhaust, and i had to work at pulling the grommet since i couldn't get much leverage and it was on somewhat snug. A bunch of water poured out of the drain when i was working the grommet, so i hope the problem is solved.
Old 01-31-13, 07:55 PM
Huongauto
Huongauto's Avatar
Hi Toptech
Can you send me this bullentine?
My car has same trouble code.
My email is autoengineervn@gmail.com
Thanks
Quick Reply: List of TSIB (Recalls/Campaigns) for 3GS
