Tpms reset
Old 02-05-10, 07:12 AM
AWDGS300
AWDGS300's Avatar
Default Tpms reset
My local shop guy broke my TPMS sensor on my wheel does anyone know how to reset the low tire light on the dash without taking it to the dealer.
Old 02-05-10, 07:16 AM
BinaryJay
BinaryJay's Avatar
If the sensor is broken then the dash will light up, there is nothing anybody can do about that other than getting a new TPMS sensor and paying the dealer to program it.
I hope this local shop guy takes it on the cheek and just pays for whatever lexus/toyota quotes you.
Old 02-05-10, 07:33 AM
AWDGS300
AWDGS300's Avatar
I got a new sensor I was just seeing if there was a way to reset the light without taking it to lexus?
Old 02-05-10, 07:54 AM
IXI187IXI
IXI187IXI's Avatar
no it has to be programmed
Old 02-05-10, 08:48 AM
PEK01
PEK01's Avatar
Each of the TPMS sensors has a unique ID code on them for the on-board computer to recognize. If one becomes damaged and needs to be replaced, the dealer who knows the software has to go in and delete the old sensor ID and enter the new one otherwise the car will not recognize the sensor.
Old 02-06-10, 10:00 AM
enigmaos
enigmaos's Avatar
are the IDs printed on TPMS or dealers have to use their program to find them?
Old 02-18-10, 08:58 PM
memasterac
memasterac's Avatar
If you have a new tire pressure sensor, it needs to be registered to the car's ECU. I don't know if the ID is printed outside but it can be detected by a handheld OBD and your tire shop shall have it.
My tire shop programmed 4 new tire pressure sensor IDs (Non Lexus brand) and the check system warning lights and message went away. So it is not necessary to go to the dealer. Just remember to reset/initialize the tire pressure (button located on the panel underneath the steering wheel, check your owners manual) at the end. https://www.clublexus.com/forums/5232696-post591.html
Old 08-18-10, 07:08 PM
fawghan1
fawghan1's Avatar
Anyone found out how much the dealer charges to program the sensors TPMS?
Old 08-19-10, 10:29 AM
LB23
LB23's Avatar
Can someone tell me if this are OEM, they are cheap
http://www.wholesaletpms.com/Lexus_G...S_Sensors.html
I have to buy the one that says $35 each.., right?
I also got this link, but here they are more expensive
http://www.statracing.com/oem-replac...rt=TPMS+Sensor
Bgw70
07-03-23 11:32 AM
tucker21
05-19-16 05:26 PM
freeflight
06-07-15 09:39 PM
seouljahon
11-25-12 07:45 AM
GQis350
08-26-12 08:35 PM
Quick Reply: Tpms reset
