F-sport Wheels - Experts Please Help!
All - I am tempted to order the Fsport wheels, which I love and think are GREAT... so I have some questions I hope you can help with:
1) Does anyone have pictures of a GS with these wheels already (prferably a G in Smokey Granite Mica)
2) Does the offset on these wheels indicate they will be more flush with the fenders?
3) The recommended tire size from Lexus is: 1
Front: Tire: Michelin Pilot Sport PS2
225/35ZR19 88Y XL
255/35ZR19 96Y XL
Is this the maximum size I can put on there without rubbing and to ensure a flush alignment with the fenders???
Lee
225/35ZR19 88Y XL
255/35ZR19 96Y XL
Lee
2009 Chicago Auto Show
Exterior:
- 4 piece Ground Effects Kit and Grille Insert by Five Axis
- Lexus Genuine Accessory Rear Spoiler
- PPG Vibrance Orange Glow 3-Stage Candy Paint
- Satin Titanium Accents
Engine:
- F-Sport Carbon Fiber Engine Cover
- F-Sport Performance Exhaust
Brakes:
- F-Sport Performance Front Brake Upgrade Kit
- 355mm x 32mm Rotor
- Six-piston opposed, 2 piece fixed, bolt-in-bridge caliper
- F-Sport Performance Rear Brake Upgrade Kit
- 345mm x 28mm Rotor
- Four-piston opposed, fixed, bolt-in-bridge caliper
Suspension and Chassis:
- F-Sport Shocks
- F-Sport Lowering Spring Set
Wheels:
- F-Sport 19" Forged Aluminum Wheels
- Front: 19" x 8", ET40
- Rear: 19" x 9", ET40
Tires:
- Yokohama Advan Sport Ultra-high Performance Tires
- Front: 225/35ZR19 88Y
- Rear: 255/35ZR19 96Y
Exterior:
Engine:
Brakes:
- F-Sport Shocks
Wheels:
Tires:
Lee
Lee
I believe I read on Sewell's website that the F-Sport wheels have to be purchased with the F-Sport lug nut set ($150). So that may also allow extra room for your spacers.
exclusive matchup
When I bought the spacers, I changed out the lugs to +5mm over factory.... I have enough now, so assuming the wheels themselves aren't thicker than the factory (i.e., more wasted stud length within the hub of the wheel), I should be fine... but, GREAT tip and something to bear in mind when they are mounted...
Lee
Lee
most aftermarket wheels use cone type lugs. i wonder if that's the reason.
but regardless, the lugs shouldn't determine how much stud distance you have to play with though
lexus114
NX - 1st Gen (2015-2021)
03-12-18 04:27 PM
