Does 2006 GS300 run on Timing belt or chain?
I am looking at a used 2006 GS300 for my next car. I know it has a unique 3.0 V6 engine (discontinued after 2007 with the introduction of GS350). Toyota doesn't seem to be using this engine in any other cars in the U.S.
Does it run on timing belt or timing chain?
The current Camry 3.5L V6 runs on a chain. The model(s) before runs on a belt (3.3L and 3.0L MZ-FE type engine).
Thanks guys for clarifying the engine chain question. I will start looking for my GS300 soon.
Also the direct injection makes a different noise...lol, does the GS300 hav direct injection, im not sure..any wayz the GS is a great car no matter the number after it....
Lexus Connoisseur
Regardless of being a timing chain, it too needs servicing as well.
Toyota GR engine
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Toyota GR engine
Manufacturer Toyota Motor Corporation
Production 2002–
Predecessor Toyota MZ engine Toyota M engine Toyota JZ engine Toyota VZ engine Toyota G engine
The Toyota GR engine family is an open-deck, die-cast V6 piston engine series. The GR series has a 60° aluminum block and aluminum DOHC cylinder heads. Some versions use MFI fuel injection, some have direct gasoline injection, and some have a combination of direct injection and MFI. This engine series also has 4 valves per cylinder, features forged steel connecting rods, one-piece cast camshafts, and a cast aluminum lower intake manifold.
3GR-FSE
The 3GR-FSE adds gasoline direct injection, referred to by Toyota as "D-4". The 3GR-FSE engine is rated at 256 PS (252 hp/188 kW) at 6,200 RPM and 32 kg·m (314 N·m/231 ft·lbf) at 3,600 RPM.
Applications:
2005 Toyota Mark X (Japan)
2005 Toyota Crown Royal (Japan)
2006 Lexus GS 300 (US and Europe)
Toyota GR engine
Production 2002–
3GR-FSE
Applications:
budmantom
04-25-14 04:02 AM
