GS350 Rear Camera
Old 11-01-07, 08:36 PM
dafatha00
dafatha00's Avatar
Default GS350 Rear Camera
Had a question for you guys regarding your backup camera. When I put it into reverse and the camera activates, the lens is aimed partially towards the edge of the license plate holder. This means that the bottom of my NAV screen is partially obstructed, but I can still see about 80% of everything else behind me.
I'm not sure if it was like this when I first purchased the vehicle, or if somehow the camera was somehow knocked out of place.
The dealer told me it was normal and the IS250/350 was like this as well.
Is everyone else's backup camera like this, or can you see everything behind you?
Old 11-02-07, 04:23 AM
gs9351
gs9351's Avatar
Exclamation Back-Up Camera
There is nothing wrong with your backup camera. The partially obstructed image is normal...given the wide angle of the lens, the upper curved surface of the bumper will show up on your screen. I observed this early on but it's a minor problem. Also, bear in mind that the apparent image distance imaged on your screen appears to be greatly exaggerated...virtually the same caveat applies as with using your RHS mirror ... "objects may be closer than they appear" ...well you get the idea.
BTW you should still turn your head around regardless when reversing, because the rear view doesn't image what could be in the way on the left and right hand sides of your vehicle.
Do not rely 100% on your camera...you may certainly regret it someday!
Old 11-02-07, 05:10 AM
MadDawg350
MadDawg350's Avatar
Could your obstruction be from the license plate holder itself?? I have a metal license plate frame around mine with ZERO obstruction. Like gs9351 stated, turning your head and looking over your shoulder while reversing is the best way to see what is behind you.
Old 11-02-07, 01:40 PM
BKE420
BKE420's Avatar
I have a clear smoked plate cover with absolutely no obstruction. It's somewhat disturbing to read other posts where the dealers are telling the buyers "It's NORMAL"....maybe time for a second opinion(another dealer).
Old 11-02-07, 01:47 PM
TandaT
TandaT's Avatar
It IS actually normal. That way you can "kinda" gauge the distance from your rear bumper to the object.
Old 11-02-07, 04:53 PM
07350FROST
07350FROST's Avatar
Originally Posted by dafatha00
...the bottom of my NAV screen is partially obstructed, but I can still see about 80% of everything else behind me.
is this about 80%?? i have no idea, but this is my view. i suspect its about the same for all!
Old 11-02-07, 11:23 PM
dafatha00
dafatha00's Avatar
Ok, I feel a lot better now. That is almost identical to how my rear camera looks, with the upwards slope on both left and right side.
Old 11-03-07, 01:38 AM
starstreak
starstreak's Avatar
The slopes are from the fisheye lens they use. Has to be something like 18mm-23mm lens to get it that wide. What always bothered me was the lens is NOT in the center back of the car, but to one side.
Old 12-11-19, 08:18 AM
zakirrrr
zakirrrr's Avatar
so .. i am guessing no body changed their backup camera yet
NormzGS350 (01-24-22)
GibbsLexus
RX - 3rd Gen (2010-2015)
24
01-23-18 12:27 PM
FatherTo1
07-21-16 10:32 PM
RookieLEX
ES - 5th Gen (2007-2012)
06-29-16 02:43 PM
LexBrett
06-09-15 01:56 PM
scsracing
01-16-15 07:47 PM
Quick Reply: GS350 Rear Camera
