2000 Gs 300 hesitation
Hey I'm having a small hesitation with my car...seen to only happen if I ty to hit it out the gate or if I brake down real quick say coming off the high way an I accell very quicky.....no check engine light no miss fire no nothing every things great.....any body have this problem with there Gs300...???
My OCV was sticking... I had a pending 1349 when I first go the car. Cleared it and it didn't return, but the car would periodically hesitate.... I'd have to get further on the pedal than normal for her to really kick in... and would have to floor it for it to ever kick down a gear
I pulled mine, and actuated it manually and it was dragging and sticking. I disassembled it and cleaned it and reassembled... fixed my hesitation
So... just a thought.... you can have an issue with it without getting codes.... and it certainly hesitates and/or lacks power if it's not functioning properly
I did that as well 8 dallors can of spray you only need one time....lol lm driving it right now I'm doing about 30 mpgs then I just hit it a Lil bit it sputter for a few seconds an takes off.....I've changed everything possible like I said no sings of any engine trouble at all....
Mine was doing the same thing when I first got it about a month ago, probably worse. Cleaned the MAF sensor with the CRC sensor cleaner, took the TB completely off to clean it real good with the CRC TB cleaner, and I also checked for any vacuum leaks.
Helped solve the problem.
Bad gas perhaps? I'm diehard Chevron but I stray to other brands when prices soar. That's when I experienced throttle hesitation. Went back to Chevron and problem disappeared.
I put octane boost an injection cleaner...Lucas,misstory oil, even went in the tank to change the filter an that one was pretty clean for it not ever been in changed for the life of the car.... but I will try changing my gas station!!
Also check the gasket of the TB. Over the years our car the gasket of the TB spent a little and start to leak in that area and that causes the hesation as well. My other recom. is be careful when you are cleaning the TB because you use the product can enter inside of the small holes that are inside of the TB and the cleaner go inside of that small holes and damage the TPS when you do that. Be careful with that. My best recommendation is to use a friend and do it with the engine running and your friend rev the engine to 1,500 rpm or 2,000 and there will start to use the TB cleaner. So you know you're just cleaned the TB and so the cleaner no goes into the small holes inside of the TB. Good luck and give us and update please.
