performance trouble with my GS300
I'm new to the forum, and am having trouble with my car . on Dec 20th my car wouldn't start at first I thought the timing belt broke , (thats how it sounded ) but NO after a while it started . however after a few day of driving it began to idle rough after warmup then i noticed that the VSC on and VSC off light was on and the backup light on as well . what is wrong?:
Hello and welcome!
You've posted your issue in the IS forums. You might find more help in the GS section.
https://www.clublexus.com/forums/gs-models-4/
Good Luck!
Good Luck!
problem fixed
UPDATE , I took the OCV apart and cleaned the small filter with carb cleaner, disconnected the neg side of the Batt to clear the faults . Just so happened that the rear light fault was on because I did have a rear light out . Replaced that and all is well in my world again!!!! thank you for your help.
