Problem can't seem to be fixed
Old 11-05-14, 11:54 AM
Marklopez
Marklopez's Avatar
Default Problem can't seem to be fixed
Alright so Let me start off from the beggining. A couple of months back I did my spark plugs and my valve cover gaskets. Everything went good and my car was driving better than normal. Suddenly the CEL and the VSC lights come on. It was throwing the code "P0031. Which is O2 sensor. Bank 1 sensor 1" I replaced it yesterday and my ECU restareted but my light came back on after I drove a few miles. I know people say that a lot of times it's not the sensor and it can be something else. What should I check? If not should I go to the dealership for a diagnostics? Emmision are coming up. Thanks in advance
Old 11-05-14, 11:56 AM
Marklopez
Marklopez's Avatar
Ohh and for the record the car feels better and it's less sluggish with the new sensor
Old 11-05-14, 02:42 PM
lexo98
lexo98's Avatar
Anytime you get a code I would recommend to clean your battery post and cables. Reset the ECU and see if the same codes come up again. The electrical systems are super sensitive.
Old 11-06-14, 09:27 AM
DMPesso
DMPesso's Avatar
agreed
This car can drive like crap if something as simple as the battery post isnt fully tightened or cleaned. Check for an air leak as well near that O2 sensor, leaks are usually 420/430 codes but you never know worth a try. If you didnt leave the battery unplugged for at least an hour or two then you did not recet the ECU, also use the OBD to clear the codes as well.
Old 11-06-14, 09:51 AM
Marklopez
Marklopez's Avatar
Thanks I'll do that as soon as I get home.
Old 11-06-14, 09:34 PM
Marklopez
Marklopez's Avatar
I cleaned the posts and disconnected it. Let it sit for like 1 hour and a half. I guess it's the diagsosis
Old 11-08-14, 08:02 PM
Marklopez
Marklopez's Avatar
So now it's throwing p0037 which is bank 1 sensor 2. What's the reason for this?
Old 11-09-14, 10:38 AM
DMPesso
DMPesso's Avatar
Well first, did you use OEM denso O2s? You MUST use OEM O2s I can't stress that enough, don't know how many people I've heard of buying those garbage universal ones or some other brand just to have to change them again when they're CEL come backs on again. You should've just changed them all at the same time to avoid this. If you have the money change all the o2s because eventually they're GONNA go bad anyway so your gonna save yourself on labor unless your doing them yourself
Old 11-09-14, 08:58 PM
Marklopez
Marklopez's Avatar
Yes I used denso. I'm just curious on why putting a new one caused the other one to go bad
Aspect
10-28-21 06:21 PM
NWiatrak
RX - 1st Gen (1999-2003)
08-21-18 08:12 AM
kryolla
06-10-14 01:07 PM
kccapt
SC- 1st Gen (1992-2000)
01-16-03 11:29 PM
Quick Reply: Problem can't seem to be fixed
