Wheel sensors
Wheel sensors
Not much information out on these things. I need to replace my front passenger sensor. The part number is 89542-30160. I was given the wrong sensor from a is300 part number 89542-51010.
The wires and sensor looks the same but the connector is different. Will it work if i swap connectors???
I always try to use Rockauto.com as a reference first. Think I found it there. ABS wheel speed sensor?
Drill down to your ride and find it under Brake/Wheel hub
Greater minds than I can tell you to swap the connector ends. I'd be soldering+heat shrinking and not butt-connecting the wires if that is acceptable.
http://www.ebay.com/itm/98-05-OEM-NEW-LEXUS-GS300-ABS-SPEED-SENSOR-LEFT-FRONT-WHEEL-99-00-01-02-03-04-/331332588446?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AGS300&hash=item4d24f6139e&vxp=mtr
fwiw i bought all mine used after i smashed/ripped both fronts when i lowered the car.
ES2501990
19
10-23-16 07:49 AM
