My 01 gs300 will hang between 2nd and 3rd gear
Old 08-18-14, 04:12 AM
ALHARTHI
ALHARTHI's Avatar
Exclamation My 01 gs300 will hang between 2nd and 3rd gear
Sometimes the transmission in my 2001 gs300 will hang between 2nd and 3rd gear
speed between (50-70 Mile) and then slam into gear. This only happens occasionally. Has anyone else had this problem. The dealer is puzzled. Thanks for any help.
Old 08-18-14, 08:41 AM
DMPesso
DMPesso's Avatar
try resetting the ECU by disconnecting the battery for at least an hour that will help AND make sure you drain and refill the tranny fluid at least 3 times. That should do the trick...
Old 08-18-14, 09:13 PM
ALHARTHI
ALHARTHI's Avatar
I disconnected the battery many times no benefit and I changed the fluid of gear with filter (TOYOTA)
the problem go and come agine !!!!?
Has anyone else had this problem??? and solved ????
Old 08-19-14, 04:40 AM
DMPesso
DMPesso's Avatar
Default .
If changing the fluid and filter helped and it came back that is your problem like I suspected. Your fluid needs to be drained and refilled at LEAST 4 times! You didn't listen when I said that. Once is not going to do anything what so ever. I guarantee you after draining and refilling, drive a few hundred miles between each drain and refill and you will be all set. I had to do that on my girls 98 GS4. It was very sluggish and hard shifting. After drain and refill a few times it was a night and day difference. Also check for any CEL codes maybe you have a code for a solenoid. That would explain that as well
Old 08-19-14, 09:59 PM
ALHARTHI
ALHARTHI's Avatar
Thank you Mr DMPesso
I will try
Whate is solenoid???
Old 08-20-14, 06:18 AM
DMPesso
DMPesso's Avatar
Default .
A solenoid is an electrical wire connection that acts as a magnet of electricity to the transmission so when it goes bad it can make the transmission act funny in many different ways, mainly shifting hard or not shifting at all
Old 08-20-14, 09:26 PM
ALHARTHI
ALHARTHI's Avatar
Thank you very much
Old 08-21-14, 06:24 AM
DMPesso
DMPesso's Avatar
Let us know by updating the thread if the drain and refills are working so somebody else who is looking for an answer to this problem can come across this thread and save themselves money and time. Alot of the time people get so happy when theire problem is fixed they just dissapear and dont say what worked for them so the next person researchning that issue has no idea what to do.
Old 08-24-14, 09:14 PM
MrSlopra
MrSlopra's Avatar
This service bulletin might be worth mentioning to the tech at your dealership. May or may not be your issue.
EG005-02: 01 GS 300 & IS 300 ECM Calibration Update: Harsh 2-3 Shift During Acceleration
Old 08-25-14, 05:59 AM
RoMiLex
RoMiLex's Avatar
When does it happen, when its cold or up to temp?
I ask because mine hangs in second as im headed to work in the morning and leaving my neighborhood. So my issue is cold transmission at low speeds(30mph).
Old 09-23-14, 04:23 AM
ALHARTHI
ALHARTHI's Avatar
It happen more when hot but some time in morning !!
Old 09-23-14, 07:24 AM
wbmx1981
wbmx1981's Avatar
Search p0763 shift solenoid.
Old 10-14-14, 04:16 AM
ALHARTHI
ALHARTHI's Avatar
Thanks my God
I solve the problem " I changed all the three coil sparke " and now its good
Old 10-14-14, 09:52 AM
Deadpool88
Deadpool88's Avatar
Old 10-14-14, 07:31 PM
SC2JZ300
SC2JZ300's Avatar
Originally Posted by Deadpool88
My reaction exactly.
Quick Reply: My 01 gs300 will hang between 2nd and 3rd gear
