Power folding side mirrors
Old 07-19-14, 04:36 PM
addzlex
addzlex's Avatar
Default Power folding side mirrors
I have a Lexus GS300 MK2. If I were to purchase folding mirrors and a retracting switch, what else would need to be done in order for the retracting function to work?
Is the loom already in place?
Thanks
Old 07-19-14, 06:47 PM
77i9
77i9's Avatar
the aristo mirror switch panel w/ the fold/unfold pushbutton will not fit on the 2GS. I used a spdt switch in conjunction with 2 relays for mine. another member used a dpdt switch.
Old 07-19-14, 07:40 PM
iToaster
iToaster's Avatar
I just did this the other day using all OEM parts. You can use Aristo door ECUs and a factory switch panel hooked to the body ECU to fold them. Here's a link to my post about it. You can see the part number of the correct door ECU in my pictures, there's a few on eBay if you search "Aristo MPX." I got the LHD switch panel from Europe and swapped the fold switch in from a Japanese panel.
Old 07-20-14, 03:58 AM
addzlex
addzlex's Avatar
Thanks for your reply guys.
If I were to wire the mirrors to an external switch inside the car, would this be easy to do from your experience? It all seems a bit complex for me
Old 07-20-14, 04:51 AM
77i9
77i9's Avatar
that would be the easiest way of doing it. use a double-pole double-throw switch, just like another forum member did.
Old 07-20-14, 06:19 AM
addzlex
addzlex's Avatar
Thanks for your reply.
Do you know which fellow member this was?
lymlyt
01-28-20 08:12 PM
biacs
10-11-18 08:04 AM
botretta
08-21-14 03:02 PM
dpayne
08-04-08 07:46 AM
Quick Reply: Power folding side mirrors
