OEM engine mounts vs Megan racing's
Old 03-13-14, 12:31 PM
islexusred
islexusred's Avatar
Default OEM engine mounts vs Megan racing's
Hey again!
Shopping for engine mounts for my gs400 as it still has the original mounts. Debating between OEM and Magan Racing, they both have identical pricing. From my reaches the OEM ones have soft rubber in them compare to Meagan's which are harden rubber. Any advice or suggestion which one should i get?
Old 03-13-14, 12:41 PM
Sonic_RC
Sonic_RC's Avatar
Well with the OEM mounts being softer its definitely a more comfortable ride. The stiffer mounts may cause a little more vibrations. My original mounts are pretty worn so I picked up a set of Megans and am having them installed next week. I'll let you know if I feel anything different if you don't get a response by then.
Old 03-13-14, 01:15 PM
islexusred
islexusred's Avatar
You're doing yourself or talking it to a shop? I heard it's a tough job do to due to minuscule space to work on
Old 03-13-14, 01:32 PM
Ava92
Ava92's Avatar
For these cars I would stick to OEM. On a more performance oriented car I have gotten rigid mounts before and I liked them, the engine doesn't move when you stomp the throttle, and the vibrations are kind of cool (depends how stiff they are) If you have a 2jzge it's probably not going to transmit vibrations as much as the V8s due to the cyl layout.
ShawnOk
10-24-19 11:52 AM
emLEX
Performance & Maintenance
03-10-16 07:25 AM
PlotPoint
20
01-29-13 05:56 PM
95sc300na
02-29-12 07:14 PM
Quick Reply: OEM engine mounts vs Megan racing's
