Need Help, Fluid Leak in Bottom Rear of Vehicle
Old 02-24-14, 09:56 PM
Jacob0015
Jacob0015's Avatar
Exclamation Need Help, Fluid Leak in Bottom Rear of Vehicle
Hi there CL!
I've recently come across a new fluid leak in the rear bottom panel of my 99 GS 300. Its greenish, most likely coolant or radiator fluid or something of that nature. Problem is, I have no idea how to access this leak, given its unique position. Any input would be great, thanks!
Attached Thumbnails Need Help, Fluid Leak in Bottom Rear of Vehicle-img_2293.jpg   Need Help, Fluid Leak in Bottom Rear of Vehicle-img_2294.jpg
Old 02-24-14, 10:13 PM
tereck
tereck's Avatar
Originally Posted by Jacob0015
Hi there CL!
Looks like u have the leak from the engine area but I running down to the area where u see those drops. Jack ur car and wash it with a hose. And then start the car and trace it down to It's origin.
Old 02-25-14, 01:41 AM
Aristo722
Aristo722's Avatar
looks like Antifreeze. Check your radiator and radiator hoses, check coolant lines around the motor. Best thing to do is google a diagram of the motor, and try to follow that leak up the car and find it. Then wash it all off, and wait and see if you can find the origin of the leak. If you can smell it, and it smells kinda sweet. Then its definitely antifreeze. Good luck!
Old 02-25-14, 07:08 AM
wbmx1981
wbmx1981's Avatar
Check for leaks around the radiator, thermostat housing, radiator hoses lower and upper, there is also a drain plug on the passenger side of the engine block. I would suspect that one of these are leaking.
yaQuzza
12
12-11-11 04:38 AM
JBSC300
SC- 1st Gen (1992-2000)
08-15-11 10:36 AM
DgoES300
09-12-05 11:36 PM
Jmai22
GS - 1st Gen (1993-1997)
02-20-03 11:33 AM
Herm
Maintenance
02-02-03 04:40 PM
Quick Reply: Need Help, Fluid Leak in Bottom Rear of Vehicle
