What brand O2 sensors are you using? Does it matter?
Old 06-08-13, 07:14 PM
4play4dr
4play4dr's Avatar
Default What brand O2 sensors are you using? Does it matter?
Does it matter? Will autozone/o'reilly brands suffice? What brands to stay away from? Needa replace for smog
Old 06-08-13, 09:31 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I heard Bosch are good but u could always stay with Denso
http://www.rockauto.com/catalog/more...225&cc=1356072
Old 06-09-13, 11:57 AM
nezlyfe
nezlyfe's Avatar
I've used the universal Denso and cut the old connector and it worked fine and cheaper than oem fit.
Old 06-09-13, 07:47 PM
newgsman
newgsman's Avatar
For the post cat O2 sensor I put in a generic aftermarket about 800 miles ago and so far it is working fine. GS400. I was getting code P0161. Paid just under $40. Even passed my emissions test a couple of days ago.
Old 06-10-13, 06:05 PM
steventrrr
steventrrr's Avatar
seeing as to how you are in CA, where emissions is a pain in the ***, I would stick with Denso. if it is your post cat o2 sensor(s), make sure it's not your cat before you buy some o2 sensors. On my old car the cat was going out and it would throw codes for the o2 sensor.
Old 06-10-13, 10:24 PM
Hollywoood
Hollywoood's Avatar
^^^^^^ good info.. Gotta change mine
Old 06-11-13, 05:07 AM
SaiyanGS3
SaiyanGS3's Avatar
I've used both Bosch and generic aftermarket in my old Q45 and both of the worked. I haven't had the need to replace any in my GS yet, but when I do I will purchase something from Rock Auto. Honestly I would probably search and see what who made our OEM sensors and buy the same brand.
Old 06-11-13, 01:15 PM
GS4_Fiend
GS4_Fiend's Avatar
Bosch and Denso are OEM replacement. But I would stick with Denso.
Old 06-11-13, 03:15 PM
AZTurbo
AZTurbo's Avatar
I used the NGK units that have the correct harness, not universal. I have not had an issue with them.
Old 06-12-13, 09:39 AM
4play4dr
4play4dr's Avatar
For the universal ones..u guys just spliced the harness onto the old one?
Old 06-12-13, 09:46 AM
Ursus
Ursus's Avatar
I used the cheapest from rock auto AWPI or something like that. Direct fit came with connector ( no splicing ) and even had anti seize on the thread.
Old 06-12-13, 12:21 PM
SaiyanGS3
SaiyanGS3's Avatar
Good info to know.
Old 06-12-13, 01:12 PM
GS4_Fiend
GS4_Fiend's Avatar
why in the world would you want to splice? buy it from denso, it's plug and play bro.
Old 06-12-13, 03:19 PM
steventrrr
steventrrr's Avatar
^agreed. should never splice into factory wiring unless you need to.
Old 06-12-13, 05:20 PM
4play4dr
4play4dr's Avatar
I was thinkin the same..some ppl were saying cut the old connector off? But ima go with plug n play for sure! Thanks fellas
JoeBlob
Performance & Maintenance
02-08-18 08:12 PM
Rock-a-Lex
09-21-14 11:48 PM
flipinsayi
GS - 1st Gen (1993-1997)
08-19-09 05:48 AM
wifeses300
02-07-07 10:42 PM
Quick Reply: What brand O2 sensors are you using? Does it matter?
