I wanted to make sure before ordering, but if I have a Supra TT brake kit on my GS400. I order the pads and rotors per part numbers for the Supra right?
Have a supra TT brake kit as in full brakes? If so, It would make most sense to do so.. you certainly wouldnt go back and order OE gs400 rotors and pads.
thanks guys ..... Currently the rotors vibrate when I press the brakes ... can't resurface since they are cross drilled .... and I need replacement rotors and need to reference a part number
you can resurface cross drilled and slotted rotors just need to find a shop that will do it. i had my slotted ones redone before i installed my Stoptech kit
Mine used to do that also, I work at a dealership so I resurfaced my cross drilled once. they worked fine for about a year. But eventually they warped again a year later. not sure if it was from the EBC red pad. So i went with OEM rotors+hawk hps pads and haven't had a problem since.
