After Market Speed Sensor Wiring
Hello guys,
I search this forum, but the wiring speed monitor to the aftermarket navigation is not coming up. Can anyone help or point me to the right direction which is the right speed sensor wire so I can connect it to the navigation unit? I know the speed sensor is attached to the wheel, but do I need to run the wire with that or any another wire that I should connect to?
Thank you so much in advance guys.
Wheres your GPS? I've never wired my sensor and I get precise MPH from the GPS antenna. Nonetheless, search "Pioneer D3 install" you'll find the picture in that write up. Sadly the OP deleted ALL his pics, but someone "quoted" one of the pics (the most important one) to where to find the wire. Its under the dash by the driver side fuse panel. Its a blue plug with a violet wire.
Thank you so much Mr. Jokster. Yes, I am intending to go with the a violet wire with a white stripe located in a blue color 6 pin plug underneath the driver's dash to the left of the steering colomn. I hope it works. I get the GPS signal fine, however, I was unable to detect the vehicle speed as to what speed are you traveling so that I can set the speed limit and give me a warning if I am over speeding. So this wire will do just that if I am connecting the speed sensor to it, right?
Thanks in advance again.
bklynboi
03-25-10 08:53 PM
draikonz
05-14-07 05:13 PM
johnp66
13
06-18-06 08:32 AM
LexCarPC
06-24-05 08:31 AM
