what i notice about throttle body and tensioner pully
Old 07-27-12, 07:33 PM
maxx430
maxx430's Avatar
Default what i notice about throttle body and tensioner pully
I was changing my spark plug and decided to clean the throttle body. I notice in the natural state, the throttle body valve does no close all the way. it is slightly open. In pic one, the valve is natural and angled. in pic 2 i held it close. is that normal?
another thing i noticed is that my pulley is huge! it causes the belt to rub against the power steering pulley. if you can notice the end of the belt is starting to tear and i do get a little screeching now. what is not right in this situation?
Attached Thumbnails what i notice about throttle body and tensioner pully-1.jpg   what i notice about throttle body and tensioner pully-2.jpg   what i notice about throttle body and tensioner pully-b1.jpg   what i notice about throttle body and tensioner pully-b2.jpg   what i notice about throttle body and tensioner pully-b3.jpg
Old 07-27-12, 07:41 PM
818GS
818GS's Avatar
You have to loosen your throttle cable.
Old 07-27-12, 09:29 PM
porn-adkt
porn-adkt's Avatar
First off ALWAYS list in your post the car and Engine you have..
1. Dont listen anything 818gs has to say.
2. TB looks fine. I hope you didnt spray cleaner straight into it, either way be prepared for High idle.
3. You have the wrong pulley for your car. its most likely Napa,Doorman, etc.. Lexus has to different Part # 's for that pulley.
A. the correct one. #166030W030
B. the one you have. #166030W010
I doubt you bought it from Lexus since they always ask for your Vin# for part match reference. Go to Sewell or your local Lexus dealer and get it. AUTOZONE/Pepboys WILL ONLY have the one you have now.
Old 07-27-12, 09:35 PM
sam12345
sam12345's Avatar
I got the right one at rock auto
Old 07-27-12, 09:49 PM
maxx430
maxx430's Avatar
sorry i have a 01 gs430.
thanks for the quick response. i will purchase the correct pulley
Old 07-28-12, 07:00 AM
SorrGwa
SorrGwa's Avatar
throttle plate doesnt close all the way so u can idle. other manufactuers have different ways to allow cars to idle, like bypass valves.
as for the pulley, it does look pretty big. the tensioner on the lexus i believe comes with locktite of some sort. i remember trying to remove the pulley and changing it before, only to have the threads on the tensioner go on me. i ended up replacing the whole tensioner itself.
Old 07-28-12, 07:31 AM
sam12345
sam12345's Avatar
http://www.rockauto.com/m/mobilecatalog.php
http://www.rockauto.com/catalog/moreinfo.php?pk=366368
Old 04-05-15, 08:48 AM
BayAreaLex
BayAreaLex's Avatar
Noticed this myself.
For a '01-04 GS430, all the parts stores tensioners show a 102mm pulley diameter (Gates, Hayden, Dayco, Goodyear).
The correct diameter is 90mm which the parts stores show only for the '05 GS430.
When it comes to the tensioner for a GS430, the parts stores are in a big cluster F. Just get OEM and or you'll be driven insane (like this guy below who ordered a 102mm parts store tensioner): notice the tensioner pulley is touching the PS pulley because it's too big
https://www.clublexus.com/forums/attachments/gs-second-generation/253942d1343442766-what-i-notice-about-throttle-body-and-tensioner-pully-b2.jpg
Old 04-05-15, 07:42 PM
D3V3LOP3R
D3V3LOP3R's Avatar
Glad I'm not the only one that had this issue...When I ended up getting the right size pulley for my tensioner they had it listed as an idler pulley.
Old 04-05-15, 08:06 PM
BayAreaLex
BayAreaLex's Avatar
As I mentioned, if you have a '01-04 GS430, look up the '05 GS430 at the parts store so you get the 90mm diameter pulley (and not the 102mm).
Since the part number system is screwed up, most people buy the part, go to install it, and only then realize something is wrong... pain in the ***.
bbqness
07-08-12 03:27 PM
gebo
IS - 1st Gen (2001-2005)
07-19-11 10:14 PM
x2mkx
05-18-09 08:07 PM
1siksc
SC400 / 300 Classifieds
02-01-08 11:33 PM
Suneet
12
06-07-07 11:33 PM
Quick Reply: what i notice about throttle body and tensioner pully
