I'm Screwed - Actuator Motor Replacement Problem
Old 07-24-12, 02:43 PM
krawfo
krawfo's Avatar
Default I'm Screwed - Actuator Motor Replacement Problem
I'm supposed to leave for vacation in 2 days and I'm in a pickle.
I replaced the drivers door actuator motor this afternoon was was testing it out. I put everything back together and layed the door panel back on the door. I closed it and proceeded to test the locks.
Now the door won't open and won't unlock !! When I manually flip the unlock switch, it doesn't feel solid - like maybe the cable slipped out of the collar that holds it.
How in the world am I going to acces the lock with the door closed.
Whew !!!!! Managed to get the door open by simultaneously lifting the door panel while pulling up on the outside door latch. The locking cable had slipped out of it's attachment to the door handle. Now everything works. The only weird this is when you lock the doors from the switch on the drivers door, I hear the lock click, the door is now locked and then you hear it click again - door still locked. I guess this is no big deal as long as everything continues to work.
The drivers side rear door will only lock or unlock using the manual switch in it's door. I guess that actuator motor is toast also. That will have to wait until after vacation.
Old 07-24-12, 02:53 PM
abounly
abounly's Avatar
Pry the door panel off enough and manually open the door
Old 07-24-12, 03:14 PM
Lazy
Lazy's Avatar
Maybe the cable came off the door handle area? I did 1 yesterday and it had 4 cables that u need to pop back in.. 2 on the outside door handle and 2 on the inside door handle
Old 07-24-12, 03:42 PM
krawfo
krawfo's Avatar
No way to get the panel off with the door closed and locked. See my original post for follow up.
Old 07-24-12, 03:43 PM
krawfo
krawfo's Avatar
Lazy, you nailed it. See my original post for update.
Old 07-24-12, 04:10 PM
DosyBoy
DosyBoy's Avatar
Actually yes their is, i see u got it open BUT, u just keep prying up on it with your tool of choice , mine was a screwdriver, did it twice..
Old 07-24-12, 04:25 PM
805Aristo
805Aristo's Avatar
So with the door stuck closed pry the door panel up with something?, asking because I'm on the same boat .
Old 07-24-12, 04:28 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
This happened to me once.......
***BAD MEMORIES***
Old 07-24-12, 06:47 PM
DosyBoy
DosyBoy's Avatar
Yep exactly, as long as the screws arent in the panel yet, i used a screwdriver, It really sucks but what are u gonna do, make sure u put a rag against the metal of the screwdriver u are using to pry against the panel with the seatbelt is, if not, u will ruin that leather panel with screwdriver marks like i did....
Old 07-24-12, 09:01 PM
Lazy
Lazy's Avatar
Easy fix! U did the DIY rc motors or bought the whole thing? Costed me $17 for 4 rc motors and 3-4 hours to install 3 of them big saving lol
Old 07-25-12, 07:26 AM
GShalfPst4
GShalfPst4's Avatar
I plan to do the same thing, I hope I don't run into any "door won't open" situations!
Old 07-25-12, 11:53 AM
SoCal Cyco
SoCal Cyco's Avatar
what do you mean replace the rc motors? i heared you have to replace the actuator? more insite pease, thanks
Old 07-25-12, 12:09 PM
DosyBoy
DosyBoy's Avatar
U can pry the actuator open and replace the small motor that is bad instead of buying a new actuator, i did it, not fun but it works and i saved hundreds as opposed to several motors for like $10 on ebay, theres a DIY on here about it....
Old 07-25-12, 01:08 PM
Kyle Harty
Kyle Harty's Avatar
The DIY thread is stickied, actually at the very top of the page at the moment. I did one with this method, well worth the savings.
Old 07-25-12, 01:49 PM
SoCal Cyco
SoCal Cyco's Avatar
anyone in socal wanna do this for me i will pay/food and beer? lol
Quick Reply: I'm Screwed - Actuator Motor Replacement Problem
