muffler delete with branch antiresonator
Old 07-09-12, 05:15 AM
sam12345
sam12345's Avatar
Post
Originally Posted by BlKTC
whoa, that's interesting.. what size is the piping that you used? for both the actual pipe and the 90* bent tube branch thing? From the looks of it, it looks like 3" piping
3" for the main pipe because of the borla tip. The branch is 2.5 inch but I should have used 3" I think the 3" would have reduced or eliminated the little bit of. Drone I have at 1400 rpm
Old 07-09-12, 05:25 AM
sam12345
sam12345's Avatar
Originally Posted by PUREgs
Nice sound! I was debating on muffler delete.....But i like the look of stainless mufflers too =/
This can be used with a muffler. You put your muffler on first and then if you have a resonant that is annoying you use a frequency analyzer To determine the resonant frequency. Once you know the resonant you add the branch to the appropriate length to eliminate the resonant, this way you can have the louder sound but not the annoying drone. The only draw back is the extra weight of the piping since its about 27" long. What I did was make it longer since longer can always be made shorter, with the cap at the end not welded. Then I slowly removed some till I got it just right to eliminate the drone. I kept the original flange and bolted to it so I can remove the entire setup and add the original muffler back on at any time. I am not going to weld the cap because from time to time I want to be able to open it so I can clean it out since I think moisture can accumulate since there is no exit.
Old 07-09-12, 09:16 PM
duy
duy's Avatar
i have a muffler delete with custom tips it sounds mean as hell
Old 07-09-12, 09:45 PM
sam12345
sam12345's Avatar
Duy, doesn't the resonance drive you crazy? With this you have the same sound on the outside but without the drone
Old 07-09-12, 10:37 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
i personally like the drone in the lower RPM's... after that its cruising time
Old 07-10-12, 12:05 AM
duy
duy's Avatar
nope i love hearin it , its pretty damn loud tho around 2k rpms
Old 07-10-12, 01:01 AM
bigwes
bigwes's Avatar
Originally Posted by tmf2004
I recently just deleted my 3rd muffler and installed the Top Speed Pro Y-pipe with smaller resonators.. Sounds pretty good.. Will try to post a vid this week... It seemed louder before i did the 3rd muffler delete with the y-pipe but now it seems like a more refined and tuned sound.. Definitely louder but no drone at cruising speeds...
Nice videos
U definitely need to post a vid. I want to delete my 3rd muffler as well
Old 07-10-12, 01:11 AM
bigwes
bigwes's Avatar
My car drones quite a bit as well. But I'm young and I want mine as loud as I can get it
Old 07-10-12, 05:45 AM
sam12345
sam12345's Avatar
You can adjust the length to allow it to drone at lower rpm yet not drone above 2000 if you want
Sactolex
Performance & Maintenance
12
05-13-18 10:56 AM
Katsumex
RC - 1st Gen (2015-present)
12-12-17 12:49 PM
JesseWA
03-14-16 12:15 AM
TCMEDIA
IS F (2008-2014)
06-27-13 09:22 PM
k2sty1
Performance
06-08-10 06:30 AM
Quick Reply: muffler delete with branch antiresonator
