actuator broken dorr won't open even with key!
I replaced the actuator in the door and it appears broken as the electric lock won't unlock the door nor will the key unlock the door. The key turns but nothing. How can I open the door again
I hope u have ur screws already off the panel, mine were when mine didnt work and i closed it to see if my actuator would work after i switched it to test it, low and behold mu door didnt open at all, i had to sit in the passenger side and pry it up with a screwdriver, my leather running up along the seatbelt has notches all in it, i damaged the leather, i had to do this twice, NOT FUN!!
with the door open, you can check first to make sure that the actuator actuates by using the door lock button for either side. It won't lock but you can observe if the actuator tries to move the lock.
da7
11-23-11 10:26 PM
