Headlight Conversion Help
Old 05-29-12, 12:53 PM
Andrewl125
Andrewl125's Avatar
Default Headlight Conversion Help
I was looking at picking up a set of these to mod my OEM Headlights. I read in another thread that it is possible to install these and still have the auto leveling work. From looking at the junction produce link, it looks like it will only come with the actual lights. What else will I need to install these. Any help would be greatly appreciated. Thanks in advance.
http://www.junction-produce.co.jp/en...can/index.html
Old 06-01-12, 08:28 AM
YxUxMADDDD
YxUxMADDDD's Avatar
Bulbs, ballast, harness, and retrofit kit from luxurymods.com or make your own retro kit with metal strips.
Old 06-01-12, 08:48 AM
21SF
21SF's Avatar
Also while those look cool, the output doesnt compare to ls430/460 or s2000 projectors. There is somethign about a sharp cutoff across 4 lanes that looks sick!!!
Old 06-01-12, 11:41 AM
vwynn
vwynn's Avatar
if youre going to get those then look into authentic Q45 projectors made in germany
Luxurymods also sells the bracket for easy install that will keep the autolevel.
Old 06-02-12, 01:19 PM
Mr Jokster
Mr Jokster's Avatar
luxury mods bracket is for the q45's and will not work with these. The LM brackets bolt on to the factory mounts of the q45's, these dont have that, all they have is an eggshell backing that you get to have fun trying to figure out how to mount them to your headlights. Probably gonna use a lot of silicone. The issue with having the autoleveling work is with the authentic q45's. All you have to do with these is find a way to mount these to your stock bowls and you're good to go.
You can get them a bit cheaper and faster on Ebay:
http://www.ebay.com/itm/UNIVERSAL-P7...8ff19c&vxp=mtr
schanel
01-02-15 12:24 PM
mcollins11
11-16-11 09:54 PM
KevMMA
04-04-08 11:09 AM
ewingli
Lighting
10-25-07 12:26 AM
BigVIPness
Lighting
03-16-06 09:59 AM
Quick Reply: Headlight Conversion Help
