300K miles
Old 12-13-11, 01:48 AM
Busha
Busha's Avatar
Originally Posted by 400 Degrez
is it too late to go to something thicker since I've been using the synthetic
No it's not to late... change the oil to a thicker oil not synthetic run it for about 1000km flush it and then continue using the thicker regular oil
Old 12-13-11, 06:34 AM
SaiyanGS3
SaiyanGS3's Avatar
Originally Posted by GS4_Fiend
Valve stems are going bad
Is this a huge job/costly to fix?
Old 12-13-11, 08:57 AM
GS4_Fiend
GS4_Fiend's Avatar
Gotta pull out the head to service the valves.
Old 12-13-11, 02:17 PM
NEbiker10
NEbiker10's Avatar
Just Drive it...wait till it goes then just drop in a engine...
I had a 289k crown vic that would smoke like a cheech and chong. All I did was switch to high mileage Valvoline and lucus full syn oil treatment ( swap with one of the qts of oil) and it worked quite well
I am soo glad to see you are at 300k any major repairs???
Old 12-13-11, 03:16 PM
benbuilt4u
benbuilt4u's Avatar
leave stock weight oil in it and keep driving as long as it only smokes on start up i consider it normal especially at 300k most of the lexus v8's smoke at around 150k mark. mine started at 130k but only after sitting a day or 2. just keep your oil topped off
Old 12-13-11, 03:33 PM
socal72
socal72's Avatar
So the recommendation for high mileage is to not run full synthetic oil even if its high mileage Mobil1 full synthetic? I'm sitting right at 165,000 on the clock, and just did an oil change with said oil. Should I change to conventional Mobil1?
Old 12-13-11, 05:52 PM
SELFMade
SELFMade's Avatar
Congrats! 300K is a hell of a milestone!
Old 12-13-11, 08:06 PM
GS4_Fiend
GS4_Fiend's Avatar
I've witnessed a 99 LS400 clean condition with only 420k+! You would think it only had about 100k. owner took really good care of it.
Vegas
Vegas's Avatar
I would say only if the car grew up on synthetic would I keep it on synthetic.
Old 12-13-11, 08:21 PM
Busha
Busha's Avatar
When you have over 200000km you should stop using synthetic oil it's thinner so on older cars it starts to leak and so on..... If your burning oil you can add this stuff I forget the name I will try & find out tomorrow, anyway I had a VR6 that's used to burn oil & I would add this stuff and it would actually work! USE REGULAR OIL IT'S POINTLESS AND A WAIST OF YOUR MONEY USING SYNTHETIC OIL ON A CAR WITH OVER 200000km!!!
Old 12-13-11, 09:19 PM
richie3888
richie3888's Avatar
Drive it until it breaks down. Why fix something that's not broken?
Old 12-13-11, 09:33 PM
Cartune
Cartune's Avatar
fix it before domino effect
Old 12-14-11, 01:14 AM
clos430
clos430's Avatar
Originally Posted by Cartune
impressive. pic of said car?
Wow 300k! I'm with this guy! Post up some pics. of your car
Old 12-14-11, 04:06 AM
ThomasGS4
ThomasGS4's Avatar
Old 12-14-11, 08:48 AM
Mr Jokster
Mr Jokster's Avatar
Yea, switching to synthetic is a once mineral has been used you have to stick to it. On the molecular level, synthetics are all the same size (thus the reason why it protects better by making more contact to internal parts) minerals on the molecular levels are all different sizes. Once they get into gaskets, they create cavities that are larger than synthetics and then begin to seep through.
Quick Reply: 300K miles
