Ive got VIBESSSSSSS
#31
Quick update.
I didnt replace the inner tie rods.
I put on a pair of wheels from a forum member on here that were perfectly balanced and my car rides out smooth. However it went crazy on me today once i got on the freeway and started shaking like emily rose but then came back again.
#34
Quick update: Didnt want this thread to just die out without posting an update. After i tried milans wheels with ill effects on my GS i put my stockers back on. They were torqued to spec and for some weird reason the vibes were completely gone. I have no idea why they were vibrating before and not vibrating now. The only thing that changed is that they were torqued with a torque wrench instead of just being tightened with a lugnut remover.
#36
Bro, you are always, I say always, should tighten it with a torque wrench to proper specs. Alot of times you get away with just using a breaker bar or whatever, but using a torque wrench can guarantee you; it will not loosen until your next oil change, you don't over torque it(which is a common practice, if you're not sure you over do it, but very very dangerous as 30% of wheels falling off are caused by over torque to the lugs) and you don't damage your lugs and studs.
#39
thanks for the update man..im going to be doing that as well... except for me i always get the 60mph shakes...but even more oddly RANDOMLY.. i get these horrible shakes like my tire blew out and it doesnt stop until I come to a complete stop. I then wait for about 15-20 seconds, put it in drive and its fine again... Then it might do it a week later idk..uhhh
#40
#44
I replaced alot of suspension parts including new tires and the shake still didn't go away.
Come to find out i had a bent rim. So check your rims for bends before shelling out big bucks like i did.
