Just installed BOV but now CEL?
Old 10-17-11, 02:53 PM
vwynn
vwynn's Avatar
hah dam im not as crazy like you turbo peeps
OK so i placed my order for 2 new knock sensors + Intake manifold gaskets..
$328.56 from Sewell Lexus... i swear EVERY SINGLE week i find myself working on the engine bay... sigh
Old 10-21-11, 09:55 PM
vwynn
vwynn's Avatar
doing some work.
Intake mani off. Took it off in one whole piece and left the throttle body there since i didnt wanna deal with that small hose... lol it was easier for me doing so.. It took me about maybe 1.5 hours to take it off. the whole piece was held by 12mm bolts (some have torx in the middle but you can use a 12mm).
Hello knock sensor. i </3 you.,
i should seafoam my car...
so besides finding rat poop in this area... i found this :|... some bugger was HUNGRY?!?.. im debating if i should solder new wires in place of the chewed up areas... ideas? also one harness clip is kinda broken :|..
im going to call Lexus of Westminster to see if they have this in stock...
Old 10-21-11, 11:02 PM
TWong350
TWong350's Avatar
Screw the soldering. I'd go for a new one as a precaution. Don't think you want to take it apart again, do you? I think they're shielded wires too, no?
Old 10-21-11, 11:26 PM
vwynn
vwynn's Avatar
what do you mean by shielded? it looks like a normal wire lol with a rubber sleeve on the outside.
ive been searching around regarding a GS400 harness but i havent found much info on it
Old 10-21-11, 11:35 PM
clos430
clos430's Avatar
I don't know much about your supercharge set up but i do know that when you replace those knock sensors, your supposed to replace the harness as well. I don't think it's a good idea to solder those wires. BTW I rec. you use oem parts imo
Old 10-22-11, 09:42 AM
vwynn
vwynn's Avatar
i called of Lex of Westminster and the guy said they dont sell it... n said the number 1200 which i assume was the price for the whole engine harness.. iono it was kinda hard to understand him. if only Kerry was working today
Anyways the picture above is what i need and well it seems like its connected with the whole engine harness?
Old 10-22-11, 06:50 PM
vwynn
vwynn's Avatar
welp didnt get any response so i went ahead and soldered the wires n shrink wrap + electrical tape the wires.
Installed the new knock sensors and gasket.. put everything back together and now she has no CEL.
#win
Old 10-23-11, 12:12 AM
99 GS3
99 GS3's Avatar
The wire is part of the harness, so yeah the dealer was quoting you the entire harness for the engine.
The shielding mentioned is further up the wire in the loom, it is shielded for most of the run but is regular wire near the ecu and at the sensors. If the wire wasn't deteriorating and was just broken solder and heatshrinking it should be fine. They get so hot in the area the wire gets brittle and break.
If you need a new connector, toyota can get you the new clip connector for the end if you have the right part number ready for them.
Toyota part number is: 90980-11166
And is like $5 here: http://www.toyotapartszone.com/oem/90980-11166.html
Old 10-23-11, 01:02 AM
vwynn
vwynn's Avatar
thanks for the link! looking at your Sig.... I want your car
Old 10-23-11, 04:54 PM
99 GS3
99 GS3's Avatar
haha.. everythings for sale I'm not really attached to it. It's pretty much done just needs a final full tune, but the new clutch/flywheel/pp combo isn't completely broken in yet it needs to see some more miles before I pound it on the dyno..
Rellgeta
08-23-15 06:49 PM
shajbot
Performance & Maintenance
02-25-09 10:38 AM
shuiyuan
02-25-09 12:48 AM
snidehocke
02-05-08 04:51 PM
slo86
CL of Southern California
03-23-05 08:44 AM
Quick Reply: Just installed BOV but now CEL?
