what is causing vibration on driver side only, steering wheel is fine
Old 08-19-11, 10:11 PM
SnoopyBQ
SnoopyBQ's Avatar
Default what is causing vibration on driver side only, steering wheel is fine
feeling vibrations around 65mph and up only on the front drivers side area, the steering wheel is fine. I got the tires balanced so its not that. I'm thinking its one of the suspension parts?
Don't know if this is related but there's a click noise when i push down on the driver side when the car is parked for awhile but only once, after that its gone. I can only hear the click noise the first time i push down on it. Park the car overnight and push down then i can hear it again.
Lexus Service History shows the upper strut support on the front has been replaced. Is that the same as the upper strut mounts? Can upper strut mount installed incorrectly cause this? if not what can it be? Its very annoying and i wanna fix this problem, please help!
Old 08-19-11, 11:33 PM
geeznuts
geeznuts's Avatar
Lower ball joint
Old 08-20-11, 07:16 PM
BCP43002
BCP43002's Avatar
If it creaks when you hit a bump it could be the ball joints. Did you have the tires road force balanced? Are the nuts on the struts(top & bottom) tight?
Old 08-20-11, 07:50 PM
SnoopyBQ
SnoopyBQ's Avatar
no sound when i hit a bump, the tires are not road force balanced but they are balanced. i changed the rims and tires to diff ones and it still does that so i don't think its the tires.
Vibration is only on the drivers side and the sound it makes when i push down is only on the drivers side.
I gotta check if the nuts on the struts are tight. Should I just change the lower ball joints and caster arms to see if it goes away?
Old 08-20-11, 08:03 PM
BCP43002
BCP43002's Avatar
Jack up the car and see if anything is loose and compare the play of one side to the other.
Old 08-21-11, 02:19 PM
Enigmatic
Enigmatic's Avatar
How old are your tires?
Old 08-21-11, 04:28 PM
SnoopyBQ
SnoopyBQ's Avatar
One set is brand new, the ones on them right now isn't. Same thing with the new and old tires. don't think its the tires, must be suspension related.
Old 02-04-12, 10:43 PM
SnoopyBQ
SnoopyBQ's Avatar
just changed the caster arms and ball joints today but the vibrations are still there. Done alignment and road force balance too. What's next? Does bad UCA or LCA cause vibrations? bad shocks or springs? only on driver side from 40mph and up! at 65 i feel it alot!
There must be a part wrong just don't know what. I'm out of ideas!!
Old 02-04-12, 10:47 PM
GS4_Fiend
GS4_Fiend's Avatar
Check LCA and LCA #2 bushings. Also check for play on all suspension parts.
Old 02-05-12, 04:59 AM
shvc1991
shvc1991's Avatar
I'm gonna say it's a lower control arm #2 bushing that is just about done.
Old 02-05-12, 10:45 AM
SnoopyBQ
SnoopyBQ's Avatar
lower control arm #2 is the same thing as the castor arm and thats been changed with a brand new one.
Old 02-05-12, 11:44 AM
shvc1991
shvc1991's Avatar
Check your motor mounts for excessive play.
Old 02-05-12, 12:25 PM
SnoopyBQ
SnoopyBQ's Avatar
both motor mount and tranny mount changed already
Old 02-05-12, 12:26 PM
justjosh
justjosh's Avatar
Inner tie rods.
Old 02-05-12, 08:20 PM
giolex300
giolex300's Avatar
its funny, today i just finished replacing my front struts and on the way home i noticed the same thing....jacked up the car took the rim off and somehow i caught a "titty" on the tire...
Quick Reply: what is causing vibration on driver side only, steering wheel is fine
