gs300 with bmw wheels.
Old 08-02-11, 05:06 AM
trickz
trickz's Avatar
Default gs300 with bmw wheels.
hi i have a question. i seen the posts up for the gs300 with 745i rims on them but didnt get a good answer from the posts. if i redrill the 745i rims will i still need a spacer? if so what size spacer?
Also if i was to get an adapter does it really have to be 19mm? i dont want them to stick out like crazy but i do have UAS airbags
please let me a good answer
Old 08-02-11, 07:59 AM
Debonair
iModerate
Debonair's Avatar
I am far from an expert on this subject but if you use an adapter it needs to be thick enough that the wheel does not make contact with the original studs. If the original studs are 19mm the you will probably need a equivalent adapter.
Old 08-02-11, 08:53 PM
trickz
trickz's Avatar
yea i spoke to someone on here he just redrilled the holes and slapped them on with no problem.. i need a place that can redrill rims. but i dunno if it will affect my balance
Old 08-02-11, 11:22 PM
Debonair
iModerate
Debonair's Avatar
Wheels and tires are balanced from the center, not the lug holes so they should balance fine. As long as whatever shop does the re-drill for you knows what they are doing you should not have any issues.
Old 09-20-11, 10:50 PM
Slydewayz
Slydewayz's Avatar
Any luck fitting the 745i wheels on the GS?
Old 06-13-12, 04:04 PM
chuydiaz
chuydiaz's Avatar
i would like to know if u had any luck installing those rims in ur ride because i am interesteed in the same setup
thanks in advance.
Old 06-13-12, 07:40 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Redrill you don't need adapters unless you meant Spacers? Depending how flush you want it to look or how far you want it to stick out. I'm using adapters from 5x114.3 to 5x120 from Adaptec since I'm not redrilling. Front is 20mm and rear is 25mm. I'm running 20x9/10.5 +25 all around on bags. Fender work done? Yes. Hope this helps. And as far as stock style 95 wheels, redrill and slap them on. I had the style 95 redrilled And slapped them on with no issues. Oh yea, hub rings is a must. For me at least.
Old 06-13-12, 10:21 PM
cruisinvip
cruisinvip's Avatar
mine are redrilled and it looks and works just fine. My fenders arent even rolled. but thats with at 235 tire in the back.
Old 06-13-12, 10:25 PM
WLGS01
WLGS01's Avatar
Like said above, you wont need a spacer if your wheels are redrilled unless you want the wheels to stick out more, but then again getting adapters in the first place might be cheaper. As far as having the wheels cleared from studs, I believe a 19mm spacer will do.
Old 06-18-12, 08:36 PM
chuydiaz
chuydiaz's Avatar
can u post some pics of ur ride to see how it looks before i take further steps please
thanks
Sheehan1p
08-17-14 10:40 PM
pinoyx2001
Wheels, Tires & Brakes Forum
05-10-11 02:06 PM
GS300nj
Wheels and Tires Classifieds
06-03-10 09:11 PM
bigboijim
01-08-09 11:27 AM
Quick Reply: gs300 with bmw wheels.
