Out of ideas
Old 10-27-10, 03:00 PM
pizdets17
pizdets17's Avatar
Default Out of ideas
Well here goes, I am one of many with vibration issues in my GS. Here is what I've done so people understand:
this is in the last 2 months:
new ball joins
new tie rods
new tires
wheel alignment (thrice)
rf balance (thrice) on a 9700
daizen bushings for LCA#2
daizen bushings for UCA's
daizen steering rack bushings
daizen sway bar bushings fr/rr
loosen/torque all bolts
rotors/pads/calipers/hubs are 100%
new spacers fr/rear
tightened steering rack 1/4"+
With OEM 16" its almost non-existent, but with my 3GS rims I still get shimmy/vibration when my Tein SS are on the softest setting at 65mph+ getting worse the faster I drive. When its on the stiffest setting no shimmy but vibration in seats at 75-80mph. I am out of ideas...Help?
Old 10-27-10, 03:18 PM
Chin
Former Sponsor
Chin's Avatar
Wheel slightly bent?
Did you get all your balances done at the same place? What type of wheel weights are they using?
With my car, I can tell every time a stick on wheel weight falls off. After I leave my tire shop, car is as smooth as can be... then mysteriously a wheel weight will fall of and sure enough the vibration returns.
Old 10-27-10, 03:36 PM
TYPEII
TYPEII's Avatar
Did you try tightening the steering rack?
https://www.clublexus.com/forums/gs-...nes-fixed.html
https://www.clublexus.com/forums/gs-...djustment.html
Old 10-27-10, 03:43 PM
pizdets17
pizdets17's Avatar
Did you even read my post lol?
Originally Posted by TYPEII
Old 10-27-10, 03:45 PM
pizdets17
pizdets17's Avatar
No. 10+ diff balances at diff places in the last year, wheels are pretty much brand new. Your weights are not falling off, it's your car throwing them out of balance trust me:
Old 10-27-10, 04:16 PM
Chin
Former Sponsor
Chin's Avatar
I'm not sure what you mean by that statement, but if the weights on my car were there Monday and then they are not there on Tuesday. I think it would be safe to say they fell off. Tire places are lazy and sometimes wont clean the surface of the wheel properly so the weights don't stick for long.
I also vaguely remember seeing a service bulletin posted on here regarding wheel weights and the proper placement of them. I'm just trying to throw some ideas out there because it seems as if you are throwing big $ at the problem...
Old 10-27-10, 04:26 PM
onihc
I heart Honda
onihc's Avatar
maybe your wheels are not true, has excessive runout?
Old 10-27-10, 04:47 PM
Bippu147
Bippu147's Avatar
did you read what he posted? he got them roadforced and balanced on a hunter 9700, that machine also checks run out....
Dmitri you should try my Work Wheels and see if they vibrate.
Old 10-27-10, 05:26 PM
shadetree
shadetree's Avatar
do you feel it in the seat or the wheel it could be a driveline vibration
Old 10-27-10, 06:12 PM
pizdets17
pizdets17's Avatar
Well they vibrate in yours probably same in mine, but for the sake of seeing my car with wicked rims I would lol!
Old 10-27-10, 06:13 PM
pizdets17
pizdets17's Avatar
this is the 3rd set of wheels this happens with. DOES NOT happen with 16" oem's, anything bigger and all bets are off..
Old 10-27-10, 10:12 PM
MickeyLex
MickeyLex's Avatar
I've experienced the same thing. With OEM 16 inch no problem. With OEM 17 inch and aftermarket 17 I get vibration. Even tried different tires on the 17s and still have the problem. Hoping someone here finds a solution to this problem I've had for 8 years.
Old 10-27-10, 10:23 PM
pizdets17
pizdets17's Avatar
dont hold your breath...
Old 10-27-10, 11:08 PM
Newchapter
Newchapter's Avatar
My car does the same thing. My solution is that I'm selling the car... I assumed it was my coilovers. Looks like I might be in the same boat with you people.
Old 10-27-10, 11:43 PM
1SWTGS
1SWTGS's Avatar
try different brand tires,maybe bad batch of spacers.
Quick Reply: Out of ideas
