Trunk lock actuator ground w/ CB trunk
Old 06-19-19, 02:36 PM
TrueGS300
TrueGS300's Avatar
Default Trunk lock actuator ground w/ CB trunk
I wanted to share what I did to get the function of the trunk latch actuator working again after installing a Seibon carbon fiber trunk in case anyone does this and finds that it wont work (Same for a fiberglass trunk I'm sure). I was only able to physically open it with the key. I found that it didn't have ground through the carbon fiber. Obvious now. I had power and ground going to it when a helper pulled the trunk release lever from inside. I was about to order a new actuator but I was thinking it was to coincidental that it suddenly didn't work after the install. Sometimes this sort of thing happens after something gets disturbed. But in this case I tried running a ground from the latch body to the frame and it worked! So here are a few pics of where you want add ground to make it work. The latch body normally grounds through the metal trunk. So you can see the yellow eyelets I used to go from the actuator to the nearest chassis ground point.
firelizard (06-19-19)
Old 06-19-19, 09:35 PM
firelizard
firelizard's Avatar
lmao
As soon as I read the title, I died inside: In hindsight it's so bleedingly obvious, but neither I or my body guy had figured it out, and I thought my actuator was just dead like all the ones in the doors.
Well, thanks for solving the trunk issue I'd given up on.
Old 06-20-19, 05:29 AM
sbagdon
sbagdon's Avatar
Continuity... it's just not a good idea, it's the law...
Old 06-20-19, 06:37 AM
TrueGS300
TrueGS300's Avatar
Originally Posted by firelizard
lmao
Will you be able to fix it now? Or do you not have the car and/or trunk anymore?
Old 06-20-19, 06:40 AM
TrueGS300
TrueGS300's Avatar
Exactly why I scratched my head for a second before giving up and ordering a new lock actuator after I had found power and ground through the wiring. Looking back I don't know why I didn't just hit it with a power-probe to check it's function. That would have told me the same thing and a little quicker.
Old 06-20-19, 02:26 PM
firelizard
firelizard's Avatar
I'll give it a shot this weekend. I had always just assumed that the actuator just grounded through the connector and that was that. If this works I'll be very pleased.
Austinsc
Performance & Maintenance
01-08-18 07:46 AM
BigGoober
09-04-12 03:17 PM
hemogoblin
09-02-03 11:20 AM
Quick Reply: Trunk lock actuator ground w/ CB trunk
