gs400 (2jz-gte swap) AC Lines
Old 07-06-10, 09:35 PM
tuninghaus
tuninghaus's Avatar
Default gs400 (2jz-gte swap) AC Lines
hi i know there are a ton of topics regarding the GS aristo swaps to the GTE.
but my question was more specifically about the AC lines.
if i do the swap with the GS400, will the factory AC lines hook right up to the GTE swap/ac compressor?
and is the GS300 a direct swap with the AC lines when you do the GTE swap?
thanks
Old 07-07-10, 02:36 AM
japspec
japspec's Avatar
thanks
Gs400 you have to make the ac lines ill take a pic of mine to give you an idea.
Old 07-08-10, 01:14 AM
tuninghaus
tuninghaus's Avatar
so how hard was it a process to keep the AC (make your own lines) when doing a GTE swap in a GS400?
would the GS300 be a direct swap (no need for custom ac lines)?
thanks!
Old 07-08-10, 02:35 AM
japspec
japspec's Avatar
thanks!
We used the gs400 ac lines and took it to a place that made the lines fit for the swap wasnt to hard, I dont know about the gs300 ac line being a direct fit either way if you have any questions hit me up.
Old 07-08-10, 02:45 AM
JeffTsai
JeffTsai's Avatar
Yes, the GS300 AC lines are a direct fit
The 2JZ-GTE VVTi and 2JZ-GE VVTi share the same AC compressor as well. It all just bolts together easily. The only problem you might run into is the line might hit the back of the front mount intercooler depending on how thick it is and how far back you mounted it. The clearance issue is a problem for both the GS3 and GS4 ac lines where it runs in front of the condenser. I'll try to post a picture when I get a chance to take one.
The way I solved my problem is that I just crimped my own AN fittings and tapped in a AN fitting adapter where the line in front of the condenser used to be. Yes, I use race car fittings for my AC in the car
Old 07-08-10, 09:34 PM
tuninghaus
tuninghaus's Avatar
thanks guys!!
as far as a 2jz-gte swap later down the line... would it be a lot easier and better to get a GS300 to begin with? or can i get a GS400 and still be pretty compareable when time to swap?
obviously i think i would prefer the GS400 for the time being (for the power reason), but i know for sure i will want to do a GTE swap down the line so i have to keep that in mind before jumping into one.
thanks for all your input and help guys!
Old 07-09-10, 01:45 AM
japspec
japspec's Avatar
thanks guys!!
The gs300 might be slightly more available than a gs400, but the gs400 diff is better with the 2jzgte swap than the gs300 diff.
Old 08-09-11, 09:14 PM
Deception
Deception's Avatar
Does anyone know if a compressor from a 94 mkiv supra will work?
Old 01-01-12, 08:36 PM
LexiBlue
LexiBlue's Avatar
i second that notion
Old 01-01-12, 10:51 PM
JeffTsai
JeffTsai's Avatar
Physically it will bolt up to the block. I believe the AC hose routing is slightly different on the mkiv supra compressor. So you will probably have to get some custom AC lines made. Or you can use the stock GS300 compressor. Both will probably run similar prices (new custom lines VS used GS300 comp).
re-rx7
04-11-15 12:04 PM
sidwin
Performance & Maintenance
08-17-12 03:10 PM
xspsi6
09-28-11 04:33 AM
philliptie
02-07-10 08:05 PM
Quick Reply: gs400 (2jz-gte swap) AC Lines
