DIY: 2nd Gen GS Fog Light Bulb Replacement
Of all the DIYs on this board, I couldn't find one for a 2nd Gen GS Fog Light replacement. I found one for a 3rd Gen which states you have to go through the wheel well. This is not the case for the 2nd Gen which made this writeup a piece of cake.
STEP 1: GRAB A PHILLIPS SCREWDRIVER AND LOCATE THE TWO SCREWS HOLDING THE FOG LIGHT HOUSING.
FrankT (11-11-20)
Last: Pop your new bulb into the harness, twist back into your Fog Light Housing and simply install and screw your housing back into place.
Note: There is a little tab on one side of the Fog Light housing that fits into a little slot in the plastic bumper space. The Fog Light has to go back in at the same angle you took it out so that it properly fits back into the slot.
This really takes only 5 minutes per side. Really simple! Hope this helps!
By the way - if you want to change your Side Markers or the Side Marker bulbs, you have very good access to them with your Fog Lights removed from the inside. There is a separate DIY on these boards for Side Marker replacement using this method.
Good D.I.Y. with pics
Also, F.Y.I., if one wanted to put HID's in the fogs, this is the way to do it. Just mount the ballasts in those housings. What I did was I mounted the ballasts vertically, so it would be away from water, as there are some small holes horizontally in the black plastic liner. I added a relay, and ran it via the passenger side housing, up to where the battery is
oh guys if you wanna reduce the theft to these fog lights,do like i did and use a allen bolt in the phillips head screw or do like im fixing to do and get some star or security bolts (im getting mine from a buddy who does elevator repair.NOONE i know carries or owns a security bolt tool so i feel safer with them)
you can do that or like i did,i mounted my fog ballasts vertically on the backside of my crash bar....keeps them out of the way
