white smoke
Old 07-19-09, 08:10 PM
Nine9si
Nine9si's Avatar
Default white smoke
Hey guys,
I have a serious problem so im turning to the experts.
Foolishly I jumped on the freeway and floored it.. then once i reached the top and way on the freeway i noticed alot of white smoke coming out all the way home. Alot that it caused the car behind to almost stop because he couldnt see. lol.
So the next day i turn the car on and everything sounds fine and normal, nothing unusual but still throwing smoke. Not alot because i wasnt giving it gas. i keept it running for about 20 min and smoke was still coming out the exhaust.
any ideas what caused this and what my problem might be?
Ive had the car for about a year and never had this happe before. Doesnt feel wierd or anything but smoking. Its a 2000 gs400 .
Old 07-19-09, 08:20 PM
TruPlaya26
TruPlaya26's Avatar
When was the last time you changed the oil? Did you recently install a new exhaust system?
Old 07-19-09, 08:25 PM
Nine9si
Nine9si's Avatar
oil was recently changed, stock exhaust.
Old 07-19-09, 08:34 PM
SorrGwa
SorrGwa's Avatar
i dont want to say it, but fear for the worse, blown head gasket...
its not cold out is it? so there is still smoke even after the car is at good operating temperature?
Old 07-19-09, 08:35 PM
FinLIFE
FinLIFE's Avatar
white is usually coolant and blue is oil..
Old 07-19-09, 08:40 PM
GS300ToM
GS300ToM's Avatar
i smell a blown head gasket!!!!!!!!!! lol
Old 07-20-09, 08:19 AM
Infamous 1
Infamous 1's Avatar
Check this out to confirm a blown head gasket.
http://wiki.answers.com/Q/What_are_t...wn_head_gasket
Old 07-20-09, 03:32 PM
mtparker18
mtparker18's Avatar
I'm thinking its the head gasket
Old 07-20-09, 03:51 PM
tromly
tromly's Avatar
Blown head gasket for sure, not an inexpensive repair. Toyota dealer will be less expensive than Lexus. Good Luck
Old 07-20-09, 06:20 PM
jcat_350
jcat_350's Avatar
definitely headgasket. If it were an oil issue it'd be blue, if it was an issue with the cats it'd be black. Get ready to shell out lotssssssss of cash.
Old 07-21-09, 08:58 AM
Nine9si
Nine9si's Avatar
Thanks, kinda figured it might be that. Any ideas on about how much it cost to get it repaired or replaced?
Old 07-21-09, 11:49 AM
BossGS4
BossGS4's Avatar
Ummmmm a headgasket job .... bend over
You might as well do a valve job, timing belt, water pump as well because it is the same work.
Use a multi-layer headgasket and ARP head studs while you're at it.
Old 07-21-09, 02:57 PM
TYPEII
TYPEII's Avatar
Headgasket job is around $1700 to $3500, depending on shops/dealership...
Old 07-21-09, 03:13 PM
ElitistK
ElitistK's Avatar
if you do it yourself it will only cost you a new set of arp headstuds and a new headgasket, which is only $300 bux max.
Old 07-21-09, 03:21 PM
TYPEII
TYPEII's Avatar
Might as well send the cylinder heads to a machine shop and have a valve job done too...Main thing also, is to find out what caused the bad headgasket, usually the culprit is the radiator, so you might need a new one too...
Quick Reply: white smoke
