Rim fitment question..
Old 05-10-09, 07:39 PM
flawssin
flawssin's Avatar
Default Rim fitment question..
Hey guys, sorry i'm pretty much a noob at rim fitment for our GS'. I wanted to know if these specs would be too much to fit without any fender mods. Also, would I be able to drop the car without having any rubbing issues? Thanks in advance.
20x8.5 +30 (F)
20x10 +23 (R)
tire sizes: 245/35/20 (F)
275/35/20 (R)
Old 05-10-09, 07:52 PM
phillygs3
phillygs3's Avatar
20x8.5 +30 (F)
20x10 +23 (R)
275/35/20 (R)
With those tires your gonna have to roll the front and shave the rears
Old 05-10-09, 09:21 PM
[ant]
[ant]'s Avatar
thats some chunky tyres. i think you will need to go less sidewall &/or less width.
front might be okay with a roll and couple degrees of neg camber actually, thats pretty sunk fitment.
rear will need a shave though as philly says. i have 19x10 +23 w/ 245/35 and -2deg camber, rolled 1/2flat and clears *just*. so you are gonna have much more tyre so you are going to have to shave the guard lips right down to clear i think even at -2 or so camber.
Old 05-10-09, 11:20 PM
flawssin
flawssin's Avatar
what size tires would work with these rims that wouldnt require me to shave/roll my fenders, if any at all?
Old 05-11-09, 05:49 AM
Infamous 1
Infamous 1's Avatar
What kind of suspension are you on?
Old 05-11-09, 06:43 PM
flawssin
flawssin's Avatar
stock. i was planning on getting coilovers after i get the rims
Old 05-11-09, 08:24 PM
[ant]
[ant]'s Avatar
i can only comment on my setup relative to what you're getting. up front you should be okay, provided you run say -2.5 or so camber. maybe drop to a 235/35 if you can. this is a little stretch but not much and not enough to expose the edge of the wheel from the tyre or anything.
rear, look the only way to get clearance is 1) Stretch 2) Camber. i have 245/35 on 10" and the rim is actually exposed from the edge of the tyre. so its a fair amount of stretch. if you are happy to do that, do that, then im running -2.1 camber so if you run like -3 or so it should clear. If you go less stretch like a 255/35 then you will need more camber like -4 or something to clear.
It also depends how low you are as to how much camber you can get. if youre low then you will have -2 as a minimum, and can then get it to like -4 with factory adjustment
Old 05-12-09, 06:10 AM
Infamous 1
Infamous 1's Avatar
I just recently bought a set of 20s (which i have put back up for sale) and they had the same tires and everything. A roll and shave are definitely needed. There isn't a tire out there that will help you.
Old 05-12-09, 07:16 AM
criminalR1
criminalR1's Avatar
I run 20X8.5 +36mm 245/35/20 in the front and 20X10 +44mm 275/30/20 in the rear.....no rubbing ...lowerd 2in
dabs
IS F (2008-2014)
15
08-21-15 10:42 AM
TTurboPimp
05-10-14 10:41 AM
cubabarber
06-05-12 10:56 AM
meangene4
IS F (2008-2014)
15
04-19-12 02:00 PM
flawssin
07-02-09 01:35 PM
Quick Reply: Rim fitment question..
