245/35/19 Tires on 19x9.5???
I picked up a set of MRR HR2 19x8.5 35offset, Rears 19x9.5 45 offset.
Was wondering if anyone has 245/35/19 tires on 19x9.5 rims on their GS4XX? I was told this would give it a stretched look and was wondering how it actually looks so if someone has pictures that would help. Also if you have any rubbing or any issues?
I would like to go with the 245/35 tires as the tire calculator suggests that's the correct size to go with in relation to the stock 16s I without affecting the speedo.
Also, I was thinking about putting 225/35/19 or 235/35/19 on 19x8.5 for the front for a staggered look any preference on which size to go with?
I bought a set of Dunlop Direzza DZ101 245/35/19 off craigslist and found out later that 1 of the tires is bad so now i have to either find another used Direzza tire with about the same tread life or find a pair of something else.
FYI 245/35-19 on a 19x9.5 isn't exactly the most extreme stretch.
You could fit a 215/35-19 (or the narrowest 19" tire you can find) on a 9.5" wide wheel without many issues. I have 215/35-19 on my 19x10 right now.
I would run the 245/35-19 if I were you, and then downsize if you have any rubbing issues.
You might have to look into getting a spacer so the rear tires don't rub on the inside of the fender though.
I wouldn't use bigger than an 8.5 width rim for 245. Stretched tires look like garbage. If the tires are staggered and the rear is 9.5 width, go with 285 in the rear. The side wall of the tire should always be vertically straight.
