Gauge cluster.
Old 10-03-08, 12:21 PM
Vadim540i
Vadim540i's Avatar
Default Gauge cluster.
So I took apart cluster, there's two white cold cathode tubes. I don't want to go LED route because it's unnecessary hard work and won't look stock. So my question is what voltage I need to look for 110V or 220V, where can I buy cold cathode stripes or tubes with orange color? Also do you guys know what happened to this http://lextech.org/gallery/thumbnails.php?album=1 project? Did they finish it?
Cold cathode tubes around gauges.
Old 10-03-08, 01:25 PM
jcat_350
jcat_350's Avatar
Originally Posted by louiegs400
thats a great mod to do,
utterly useless post.
i believe you could buy a set of CCFL halo rings and do it, though i doubt theyd be orange like you are looking for.
i dont know of anyone that has amber or orange CCFL strips/halos, but i know AAC makes these LED strips, which you could probably change out the LED's to match, and i would assume would be brighter than the stock CCFL strips:
http://www.automotivelightstore.com/...ROD&ProdID=245
Old 10-03-08, 01:33 PM
sakataj
sakataj's Avatar
i'd be interested to see this when its finished! keep us posted
Old 10-03-08, 04:58 PM
Vadim540i
Vadim540i's Avatar
I was also thinking may be to wrap around existing bulbs orange film but then it will be too dim I guess.
Old 10-04-08, 12:58 AM
Vadim540i
Vadim540i's Avatar
Sooo... anymore ideas?
Old 10-04-08, 01:08 AM
Spyder78
Spyder78's Avatar
find a company that makes custom cathode bulbs?
Old 10-04-08, 04:35 AM
Frankdorn
Frankdorn's Avatar
I just took apart my gauges two days ago for the same reason. Funny. So yeah, I'm pondering the same. I was thinking either two strings of carefully connected 360º LEDs on either side, or custom made cathode bulbs.
I want stark white light, so I'm trying to figure out where the green hue is coming from when the gauges are reassembled...
Anyway, I wonder if a neon sign store could make those little CCFL tubes?
Old 10-04-08, 02:26 PM
jcat_350
jcat_350's Avatar
the green i think comes from the black lens casing that goes over the gauges. It's probably actually just REALLY dark translucent green that looks black until lit from the back.
it seems like those ccfl's would be expensive, and idk but those LED strips from AAC, if you could get them to work they'd look really nice i think.
Old 10-04-08, 02:32 PM
kit cat
kit cat's Avatar
I knowyou said you don't want to go LED, but what about taking a plastic ring, cut bunch of grooves, stick SMT LED at each end?
Source: A.room
btw, most angel eyes are not a true ring but a C shape, this is a complete circle which fits well with our 16 GS.
Old 10-04-08, 03:09 PM
Vadim540i
Vadim540i's Avatar
Source: A.room
Hm, that's might be good idea so 12V feed could be taken from inverter, where 12V line goes in?
Old 10-04-08, 03:12 PM
Vadim540i
Vadim540i's Avatar
Look at this thread https://www.clublexus.com/forums/sho...d.php?t=339979
Old 10-05-08, 12:28 AM
Vadim540i
Vadim540i's Avatar
Talking
So I'm finally finished with my cluster without even touching bulbs, they left stock. Now I got the idea how to change color, and I can change color to red, blue, green, yellow(right now), you name it without any LEDs or other crap.
I need your opinion how's yellow looks? Should I leave it yellow, or.....?
EDIT: pics were taking from iPhone, hence quality sucks a bit.
Old 10-05-08, 02:02 AM
burma
burma's Avatar
do it Blue, it'll look nice....but i guess since you changed your radio and interior lights to yellow so it has to match.
Old 10-05-08, 06:34 AM
Frankdorn
Frankdorn's Avatar
The only concern I'd have with AAC's strips is getting them the correct length. The LED/acrylic sounds interesting because you could coarsely sand the outside, cut to length, and heat & bend it.
I'm looking for bright white...I wonder if the dull white plastic in the background would affect it also...?
It sucks--I can't see any of these pics...at work they're blocked. I'll check back tonight.
Old 10-05-08, 06:50 AM
shvc1991
shvc1991's Avatar
How exactly did you do that if you don't mind me asking?
and if anyone knows, I have a 2000 GS3. Does that tinted black cover over the gauges cause my gauges to look green?
Quick Reply: Gauge cluster.
