Air Conditioning Problem
Old 06-17-08, 02:49 PM
PR FIEBRU
PR FIEBRU's Avatar
Post
I read up on another post that it can possibly be freon. Ill try that first and then ill go in price order. Unless someone finds out what is wrong with our cars
Old 07-23-08, 09:11 AM
PR FIEBRU
PR FIEBRU's Avatar
Adding freon fixed the problem. Now it blows cold air out of both zones
Old 07-23-08, 04:46 PM
DPK*David
DPK*David's Avatar
I thought I was the only one having this problem. I need to fix this!!!! asap. I will also try the freon first.
Old 07-25-08, 02:50 PM
darrylg33
darrylg33's Avatar
Check this thread, could be refrigerant, thermistor, servo motor, or heater core, have to work all of them to find the fix....
https://www.clublexus.com/forums/sho...ight=darrylg33
Old 07-25-08, 03:02 PM
BAD RIDES
Registered User
BAD RIDES's Avatar
it was the air dampner lexus of orlando had the car 3 days and the changed it for $900 bucks ouch bright side the service was good and free loaner its like a freezer in my car
Old 10-28-10, 04:14 PM
BLkARIST0
BLkARIST0's Avatar
Originally Posted by Bdragon007
Hey guys, I got the same problems, but mine is on both side and all it does is blowing cool air from 65 to 84 degree the only time it give out heat is when i put in 85 but that is wicked hot....i have know idea what happen i wonder if anyone have experience the same thing and let me and HaydenGS know what cause it. Thanks!
did you or anyone ever figure out this problem?? its really bothering me!
Old 07-13-12, 02:05 PM
grut
grut's Avatar
Default AC issues with LS 430
Surprise! After starting engine only hot air is blowing in my face! There was no noise, nothing seemed to break. Otherwise car drives great as usual.
How can I tell what is wrong with the Ac before I have to see the dealer? How do you see the diagnostic codes or malfunction messages on the 2005 LS 430 display?
Any DIY fix postings out there? Someone help!
Old 07-13-12, 03:56 PM
GS4nicate
GS4nicate's Avatar
Well sir, you can read through the rest of this thread and see if any of those possible fixes helps you. Pretty much covered most of the common soultions.
Oh, one more thing, maybe post this in the LS section of the forum. Those guys may be more knowledgeable of the problem and possible solutions.
Old 07-27-12, 02:41 PM
dcz
dcz's Avatar
Blowing warmer out of the passenger side vs the driver side sounds like low freon to me. Thats what my car was doing. Just buy a cheap can of r134a at your local parts store... hook it up to your low side fitting near your driver headlight... compare it to the ambient air chart that comes with the can and go from there...
lilscrapy8
07-02-14 02:20 PM
Slatts2013
08-29-13 04:41 PM
GS2low4NYC
01-08-10 09:41 AM
Orkin
11-03-03 10:32 AM
RichMartin
03-06-01 01:14 PM
Quick Reply: Air Conditioning Problem
