Sunroof wont close all the way. HELP
Well, last week I had the sunroof opened up all the way. Tried to close it and it didnt want to. It would close a 1/4 of the way and go back. Almost like it was stuck on something. Finally after sticking my hand between the sunroof and the shade cover I was able to close it somehow. Yesterday when I was leaving the gym I forgot about it and opened it again. Now it wont close and I dont want to have to take it to Lexu$. I did a search and couldnt really find anything. Maybe the motor is bad? I am hoping that someone else had this and was able to fix it. Help a CL brother out! It would tilt up no problem also, just the retracting was bad.
This has happened to me on a couple of occasions. The sunroof would act as if it was going to close and then pop open again 1/4 of the way. Basically what I did what was clean out really good the area around the sunroof trim. The first time around I did not find anything, but after cleaning it well, it worked fine and closed completely. The second time around I did clean off some two or three dried out leaves and this cured the problem as well. Also you may want to grease up what ever area in the mechanism needs greasing.
Good Luck you ya................
Loves Snickerdoodles!
you need to use a high pressure blower, and blow out the rails of your sunroof then spray some silicone in the rails. that should cure your problem.
Mine does the same thing
i just use my hand and lightly force it to close then that was it. No more problems... but i should clean the rails for sure with silicone, good idea for sure!!!!
Big Mack
Mine does this too at times. Here's my secret: When the sunroof goes to close, just before it reaches the fully close position, I hit the down button, then quickly click the close button again, and then the down button again, and then the close button again. It's worked for me for 3 years! Haha....
http://en.wikipedia.org/wiki/Konami_Code
fattiresc (07-13-23)
the same thing is happening to my 96 es300 it stops half way then it open..when i try to close it it goes half way then nothing i disconnected the battery on the car for some reason it closed all the way but its is still doing the same problem..thinking about carrying a pry bar with me everytime i open it lollll...
