asdlkfjasoiefesa BRAKE SQUEAL!!
Old 03-31-15, 07:13 PM
CLkicker
CLkicker's Avatar
Update...
Lexus corporate scheduled an appointment for me with the service manager. I took the car in and had a quick chat with him. After a few days of holding my car, the service manager and techs at Glendale deemed my car as having a normal amount of brake squeal... They refused to resurface the rotors or change the pads because the ear piercing brake squeal was considered normal and would come back anyways.
I'm officially stuck with the car... I can't sell it because no buyer will purchase the car with this amount of brake squeal and I refuse to lose money at carmax.. WTH SHOULD I DO!!?!?
Old 03-31-15, 07:17 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
My squeal has been gone ever since I painted my calipers. I did spray an insane amount of brake cleaners during the prepping stage though. I heard sometimes painting the calipers reduced brake noise too.
Old 03-31-15, 07:48 PM
gotink
gotink's Avatar
Try doing a proper break in. A couple high speed stops. This will explain how to safely. http://www.tirerack.com/brakes/tech/....jsp?techid=85
Old 04-08-15, 09:06 AM
CLkicker
CLkicker's Avatar
It's official.. Lexus corporate wants me to pay for the rotors to be changed... $900 out of my pocket for something that I didn't cause.. BS!
Old 04-08-15, 09:26 AM
ItzFilyO
ItzFilyO's Avatar
Wait.. what?! How much are the rotors for this car?
Old 04-08-15, 11:41 AM
CLkicker
CLkicker's Avatar
according to the dealer, it's about 405/rotor plus tax. So just under 900 for both.................
Old 04-08-15, 12:13 PM
rijc99
rijc99's Avatar
Can't you get them resurfaced?
Old 04-08-15, 12:43 PM
ItzFilyO
ItzFilyO's Avatar
400 per rotor.. damn what is this a Ferrari?! I think they're ripping u off big time. I thought BB06 said he got his for 100 each.
Old 04-08-15, 01:05 PM
CLkicker
CLkicker's Avatar
The dealer said they're below the min thickness and a replacement is a must..
The cheapest I found for f-sport rotors were $215/rotor shipped.
Old 04-09-15, 05:50 PM
mso4
mso4's Avatar
My brakes did the same in the beginning. Dealer agreed to replaced rotors/ pads after I refused re-surfacing. Three months later squeak again. I replaced w ceramic pads. Good for 6 months and squeaked even more than oem. I switched back to OEM and squeak gone! No idea why.
I was going to buy out this car but that brake problem left a sour taste in my mouth. Needless to say I'm turning this car in at lease end. I don't think most people have this problem. But when you do its a royal pia.
Old 04-25-15, 07:22 PM
JEFFOS69
JEFFOS69's Avatar
Mine are starting to do this too - driving me insane
Old 04-26-15, 08:16 PM
dinachroek
dinachroek's Avatar
hey guy so my GS is 2014, and i just hit 20000 miles, i start noticing the squeak like last month, it getting worst and worst. does that mean i need to replace my pads or is it not something wrong?
Old 04-26-15, 09:49 PM
JEFFOS69
JEFFOS69's Avatar
Normally a squeal is when your pads are worn down. There are little metal squealer pins that make contact on the rotor and make noise when the pad material is low however a squeek or squeal can be other things - a pad that squeaks when hitting a rotor surface due to the material composition, a problem with the caliper, worn rotors or rotors that need replacing or resurfacing, glazed rotors etc.
You have to check your pads to see if that's the issue. In the case of most of the cases posted above it seems these brakes are prone to making noise despite working properly. These cars also seem to like to go through brakes very quickly.
Old 04-27-15, 06:34 AM
dinachroek
dinachroek's Avatar
i went to the dealer other week they told me nothing wrong, they suggest i try replacing the front brake as it only 3mm thick left. however, I had a IS in the past and didn't have to replace the pads until I hit like 40000 miles.
dawgedu
GS F (2016-present)
56
09-29-21 07:03 PM
grsams
LX - 3rd Gen (2008-2021)
14
07-07-15 09:36 PM
khpark928
Suspension and Brakes
05-25-11 07:56 AM
is250gurl
09-07-07 09:09 AM
Lexus400mn
06-04-07 12:26 AM
Quick Reply: asdlkfjasoiefesa BRAKE SQUEAL!!
