Aftermarket LED daytime driving lights
This is probably not intended for the purists but I like it. They line up perfectly with the lines of the Fsport lower grills.
Yes, purchased from EBay. I wired ground to battery and positive was tapped into the ignition fuse (lower right corner of engine.). I didn't want to risk blowing out anything that had to do with the OEM headlights. This way if anything happens, the fuse will just need to be replaced.
