Programming a "pause" in the dialing string
Old 11-22-14, 03:59 PM
jkeifer3
jkeifer3's Avatar
Default Programming a "pause" in the dialing string
Hi Folks,
I have a 2013 GS Luxury. My wife's work number has an extension associated with it and I need the stored phone number to have a few second pause between the dialing of the phone number's 10 digits and then dialing the 2-digit extension.
Although the number that is transferred from the phone contains a pause (and it works when dialed directly from the phone), when I dial from the number stored in the NAV system the pause does not work. Is there a special character that the system recognizes as a pause or other way to program in a "pause"?
Thanks in advance!
Old 11-22-14, 05:12 PM
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
Have you tried a comma [,], which is old style? Or, have you tried using 'P', which is the more modern pause character? Some devices want the star key[*] to be used first, but that is usually a means to get to an internal pause feature, or allows you to add 'P' to create the pause.
Old 11-22-14, 06:20 PM
ESsearch
ESsearch's Avatar
I wish I had answer as I tried this many times myself unsuccessfully. It seems to be an example of Lexus going backwards as my 07 ES350 would accept pauses and even did "speed tones" so I could enter my voicemail password, delete messages, etc.
My only solution I came up with was to use Siri to initiate the call from my phone. Then the phone can send the strings with pauses.
Pete
Old 11-24-14, 05:53 PM
jkeifer3
jkeifer3's Avatar
Thanks bclexus and ESSearch for the thoughts. I'll try both of your ideas. I know that I was able to program in a pause in my SC-430 and was able to make it work in my '06 GS.
cykodad
08-04-16 01:09 PM
ongtroi
03-13-09 06:19 PM
CA06SC430
11-16-07 09:46 AM
SC430Sam
08-31-07 11:29 AM
kaloisa
GX - 1st Gen (2004-2009)
07-03-05 11:18 PM
Quick Reply: Programming a "pause" in the dialing string
