Climate control settings change randomly
Hey folks.
I've been driving the wife's GS Fsport more lately this summer and I noticed some things. Why is it that each time you turn off the car and when you go to use it again the climate settings change by themselves? Its not even consistent. Sometimes the AC is on while other times its off when I start the car. I prefer to have the settings stay the same from when the cars turned off and then when its started up again. The temp setting also fluctuates. Might it be trying to predict the best setting? I also never use any "auto" fan/temp settings either.
Thoughts?
Happy 4th to everyone!
Thoughts?
My settings always remain the same.
No clue. Do you leave yours on auto? Are climate functions linked to memory profiles maybe?
Hey folks.
Thoughts?
Thoughts?
I wonder if the presets extend to ventilation settings. NOTE, no matter how you try the ventilation will always reset to recirculation when the temp is 75F or higher.
Question 1 - did you tie setting (seat, mirrors, wheel) to a particular fob?
2. If so, have you noticed if the changes occur when using different fobs.
If not this, have you asked your wife/kids if they've been sneaking into the car and changing the settings when you are not there? For some mysterious reason this always happens to my home thermostat.
Good luck, Happy 4th.
First thought that came to me was the fob. I know you can tie the seat, mirrors and wheel settings to the fob in use, thus when driver (fob 1) is in the car the settings are restored to that fob presets. This is of course you have done the setup for this to occur.
I don't recall setting the functions to the fob, just the memory seats with the buttons on the door. I did buy the car used, so maybe the previous owner was messing with this?
Its a big mystery And no, our son is only 8months old, so I doubt its him, ha!
Happy 4th too.
You should dig into the owner's manual. I seem to remember reading that seats, steering wheel, outside mirrors, radio and A/C settings are all linked to the key fob. I've never looked further because I'm the only one driving my GS.
My AC is always on and that's how I like it. Most of the time all my settings are remembered but once in a while my settings change too which I find kinda annoying. I dont know if its a glitch or anything buy lexus should fix this with at least a software update.
Anyways have you tested the cars battery to see if it still holding a good charge? Sometimes a weak battery will mess with your car settings like resetting everything to default.
I've had the same problem.... the outside/inside vent would toggle by itself (in all driving modes... eco, normal, sport) without me hitting any buttons. Kind of annoying really. Doesn't happen too often, about once a month. I gave up trying to figure it out.
Thanks for the reply. You know, I never thought about the correlation of the settings and two different fobs. It could be related. I will need to check into it more. My wife and I use our own fobs but I still think we both see the settings change within the same day(leaving home & Leaving work). The temp number will be on "low" when I get to work, when I go to leave for example, it might be at 75???
Happy 4th too.
Happy 4th too.
JayGoldste
HS 250h Model (2010-2012)
05-18-13 06:17 AM
Lexterious
RX - 1st Gen (1999-2003)
07-16-03 09:19 AM
