Will the LED relay work for our vehicle?
Looking at switching my turn signals to LED. Instead of buying the LED decoders will swapping out the relay work instead?
http://store.ijdmtoy.com/12V-Electro...l-p/aa1185.htm
TIA.
TIA.
I use these for my turn signals. No relay swap needed and no hyper-flash.
http://www.vleds.com/v3-a.html
Do you have them in the front and back? Also if you just use them in the front can another led (as the rears are mounted funny and I think that powerful of a light in the rear may be too much) be used in the back since hyper flash is already addressed?
The V3 will cure the hyper flash. You will need one per side and they work perfectly. Actually the controller box of the V3 are resistor inside, install the fuse will activate it.
Once you installed the front you will want one for the rear so get them both to save on time & shipping.
There no swap-able relay in the 4GS, the relay circuit built into the dashboard controller.
I have both front and rear. I am in Mississauga if you want to meet up and check them out. Install wasn't hard at all. Rear is easier than front since there's more room.
http://www.vleds.com/resistors/turn-...resistors.html
That's quite a costly solution. Any reason why this wouldn't work?
