Officially full front LED F-sport
Old 02-06-14, 06:08 AM
jtrue28
jtrue28's Avatar
Originally Posted by Sosodef79
Looks amazing man! nice job. For the fog lights is it plug and play? does the factory pre wire it already?
Not on the F-Sport. There is a thread dedicated to the fog lights.
So the high beams don't work? Not sure I'd do this modification if it meant I'm losing functionality.
On the low beams, can you not adjust them so they point in the USA standard direction?
Old 02-06-14, 06:22 AM
yardie876
yardie876's Avatar
Originally Posted by jtrue28
Not on the F-Sport. There is a thread dedicated to the fog lights. So the high beams don't work? Not sure I'd do this modification if it meant I'm losing functionality. On the low beams, can you not adjust them so they point in the USA standard direction?
It's because the cutoff is backwards tot he of RHD cars like ours, i.e. the high point of the beam pattern will be on the left as opposed to ours, which is on the right. I hope that makes sense lol.
Old 02-06-14, 10:36 AM
onexcite
onexcite's Avatar
Why don't you get the US LED version? (US Hybrid)
Old 02-06-14, 11:09 AM
jtrue28
jtrue28's Avatar
And why don't the high beams work?
Old 02-06-14, 11:47 AM
onexcite
onexcite's Avatar
The F-Sport headlight doesn't have AFS feature and the wiring also different that's why the high beam won't work. If you have non F-sport high beam will work plug and play and if you have Lux models both high beam & AFS will work.
Old 02-06-14, 03:43 PM
SNiiP3R
SNiiP3R's Avatar
You won't find a used set in US.
Old 02-06-14, 05:28 PM
13FSPORT
13FSPORT's Avatar
Ebay had a set and there is one on there now but not a pair.
Old 02-06-14, 05:34 PM
mshmsh
mshmsh's Avatar
Looks perfect!
No one has complained about my beam pattern yet so I stopped worrying about it.
Were you able you to get the high beams to work?
They work fine like I said just re-wiring and I will post that later
Originally Posted by bigblack06
Wow looks good nice, how does it look on the road would you say better visibility than HID's or about the same.
I would say they have better visibility than HID even though I read somewhere here they LED are less lumens than HID and that was actually wrong in my opinion as those are damn good
It's plug-n-play for non Fsport models, I had zero issues. For Fsports high beams will not work, but everything else is fully functional.
they work fine it is a matter of re-wiring and ill post DIY later
Originally Posted by puckhead85
the leds headlights don't have the AFS?
they do but our US version F-sport dont
Originally Posted by yardie876
Man that looks great. We need output shots!
I will with the DIY later I am super busy I actually installed those last month and did the re-wiring this week and do not have time to take the bumper off again to for write-up till I have some free time soon. Thank you
Exactly thats how it looks.
brand new will cost $2700 each. with Sewell discount and re-wiring again will cost more and you won't be able to sell it since you are doing a re-wiring.
they do now. when I first plugged it they didn't work with auto level system because I had to re-wire.
Old 02-07-14, 05:24 AM
modthispny
modthispny's Avatar
this should have been an option on the GS!
the IS gets full LED's but the GS doesn't??
Old 02-07-14, 05:38 AM
LGSFS2012
LGSFS2012's Avatar
Very nice Mod. WOW!! What a change of look.
Old 02-07-14, 07:20 AM
yardie876
yardie876's Avatar
Ok so a couple of questions... Does part of the low beam come from the square portion under the projector? Also, the AFS does not work on the F-Sport since we don't have it or do these lights make it functional?
Old 02-07-14, 07:37 AM
vietzboi87
vietzboi87's Avatar
Looks great. The led looks way better than hid.
Old 02-07-14, 08:56 AM
stick22
stick22's Avatar
those LED's look real clean. wish there was an easier conversion though. having to do custom wiring to get your high beams to work doesn't sound very tempting
fingerstom
RX - 3rd Gen (2010-2015)
03-28-18 09:47 PM
rc11214
RX - 4th Gen (2016-2022)
69
12-07-17 01:13 PM
AustinHusk
GX - 1st Gen (2004-2009)
14
05-12-16 01:12 PM
Xenosis32
01-13-16 07:10 AM
mpbspb
NX - 1st Gen (2015-2021)
01-13-15 03:16 PM
Quick Reply: Officially full front LED F-sport
