Official Worlds 1st: USDM 2013 GS350 F-Sport w/JDM Fog Lamps Installed, Video Inside!
Old 08-05-13, 10:19 PM
  #121
WalterW
10th Gear
WalterW's Avatar
I managed to add some photos of my diagrams for N28 and others under my profile. I can scan more if it works
Old 08-06-13, 01:58 AM
  #122
Stew4HD
Stew4HD's Avatar
The pics should be very helpful. Thank you!
Old 08-10-13, 09:27 AM
  #123
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Got your PM's...
You will want to order this part number.. 93567-A5014 = (4 quantity)
Only 2 screws for each side..
Thanks
Joe Z
Old 09-12-13, 04:35 PM
  #124
Joe Z
Joe Z's Avatar
Great update for you 2013 GS owners... Lexus released their 2014 LED Fog Lamps...
Should be direct fit for Base GS bumpers & also F-Sport bumpers...
Enjoy
Jeff,
YOU ARE THE MAN...!!!
You are right.. These will be a direct P&P into the IS-F and also the 2013 & 2014 GS350..
or
Any other Lexus / Toyota that uses the same exact oem halogen lamp..
Already ordered up my set.
Thank You sir..!!
~ Joe Z
Originally Posted by Jeff Lange
81210-48050 - RH LED Fog
81220-48050 - LH LED Fog
Should be Plug 'n Play on an IS F, not so on an ISx50, I had to modify them unfortunately to fit the car. I believe that there will be an LED option on the 2014 CT200h that may be Plug 'n Play for the ISx50, but I didn't feel like waiting, haha.
LED Fog beside ISx50 Halogen Fog:
LED Fog connector (same as H11):
Installed:
Jeff
Old 09-12-13, 04:45 PM
  #125
yardie876
yardie876's Avatar
Where can I order them!?
Old 09-12-13, 06:49 PM
  #126
jtrue28
jtrue28's Avatar
Us F-Sport owners will still have to get the trim pieces and the wiring harness, and the stalk. We'll need to see if Nigel can offer this new package with LEDs. Thanks Joe Z!
Old 09-16-13, 07:13 AM
  #127
Nigel-JDMParts
Nigel-JDMParts's Avatar
For Sure!!
Old 12-17-13, 10:32 AM
  #128
Kbasdeo
Kbasdeo's Avatar
What items are needed to be ordered to make the full OEM converison? So far, the bezels, fog lamps, screws, and headlight switch; am I missing anything else?
Old 12-17-13, 11:29 AM
  #129
jtrue28
jtrue28's Avatar
wiring harness
Old 12-17-13, 04:14 PM
  #130
Kbasdeo
Kbasdeo's Avatar
wiring harness
Is there an OEM part number?
Old 12-17-13, 05:59 PM
  #131
yardie876
yardie876's Avatar
Nope, unfortunately. Your best bet would be to order one through nigel-jdmparts.com
Old 04-21-14, 12:29 AM
  #132
Blackraven
Blackraven's Avatar
Originally Posted by Joe Z
The US Spec already has a LHD stalk w/Fog Light function...
It's the same "Stalk" Ryan has pictured that is found in a Regular US Spec GS350 Premium, Luxury & Hybrid Model / Packages ..
Location 84140
Part# 84140-30360
SWITCH ASSY, HEADLAMP DIMMER $196.46 MSRP - Can be had for approx. $120
(Stalk for Premium, Luxury & Hybrid Packages / Models w/ FOG Lights)
Part# 84140-30420
SWITCH ASSY, HEADLAMP DIMMER F-SPORT PACKAGE $177.70 MSRP - Can be had for approx. $109
(Stalk for F-Sport w/ Fogs Deleted)
~ Joe Z
Originally Posted by flipside909
Here's the stalk with front and rear fog switch:
New post:
Here's our indicator stalk for F SPORT models (for Europe and Other Asia........excluding Japan):
Purpose:
To activate a single rear fog light (driver-side):
In short, asymmetric butt
Old 09-26-14, 02:17 AM
  #133
Rufio808
Rufio808's Avatar
Has Anyone done a instal Guide for the Nigel-JDM foglight "WITH" The Headlight Stock with the Fog Light Switch. Need help because Google isn't :'(
Old 11-13-14, 01:18 PM
  #134
tknx
tknx's Avatar
Okay - so I did the entire damn install and couldn't get the stalk to work. I used the Nigel-JDM kit.
The one thing that the Nigel kit sucks at, is that the wiring harness includes a panel switch, so if you are using the stalk, you need to redo the wiring to fit in the existing Lexus harness - and there are no directions.
In the stalk wiring harness - the fog lights add three pins in the top row in the 2, 3, and 4 spot. My understanding is that ground goes to the position 3. And the wire to the relay goes to position 2. That didn't work no matter what we did. Does the car have to be on? Headlights?
Also does the dash fog light indicator work?
Old 11-13-14, 02:00 PM
  #135
yardie876
yardie876's Avatar
Originally Posted by tknx
Okay - so I did the entire damn install and couldn't get the stalk to work. I used the Nigel-JDM kit. The one thing that the Nigel kit sucks at, is that the wiring harness includes a panel switch, so if you are using the stalk, you need to redo the wiring to fit in the existing Lexus harness - and there are no directions. In the stalk wiring harness - the fog lights add three pins in the top row in the 2, 3, and 4 spot. My understanding is that ground goes to the position 3. And the wire to the relay goes to position 2. That didn't work no matter what we did. Does the car have to be on? Headlights? Also does the dash fog light indicator work?
Yes, the fog light indicator does illuminate. Can you post a pic of the harness and where it plugs in? I have to fix mine and have no idea where it is lol.
Quick Reply: Official Worlds 1st: USDM 2013 GS350 F-Sport w/JDM Fog Lamps Installed, Video Inside!
