DIY Fuel Filter change/replace
Old 04-26-14, 04:50 PM
saiko2j
saiko2j's Avatar
Exclamation DIY Fuel Filter change/replace
so i have decided to be an awesome individual and show you all how to replace a fuel filter....
1. fuel filter is by the rear left tire, right under the door.
2. here's a picture of what it looks like with the cover removed.
3. you really should use a back up wrench, here you need a 14 mm and a 17 mm, both ends the same..i sprayed PB BLASTER 20 min before i started to unbolt/unscrew everything.
4. here you cal see after i losend both ends, in coming and out going, in coming is the right side the clear fuel that's dripping, on the left if the going to engine pipe and you can see how dirrty that fuel is.
5.i couldnt believe it my self, i had an OEM toyota fuel filter in there.
6, this took me about 30 min to complete
PS. making these DIYs is not easy lol.
Old 04-26-14, 05:08 PM
TRACKMKIII
TRACKMKIII's Avatar
Thanks for the wtite-up!! I change my fuel filter a few months ago and it was original too. Whats really scary is when you dump the old filter and see all of the dirt/glunk that goes through your fuel system.
Old 04-26-14, 06:40 PM
saiko2j
saiko2j's Avatar
yup, i kept the filter, i will cut it i half and post those pix up to,
Old 05-18-14, 09:12 PM
ClarkKent
ClarkKent's Avatar
I did the same thing about 3 months ago. Yep mine was the original too. And yes the crap that came out the front side baffled me. How do these things go for so long on that dirty fuel. I dunno... Thanks for the post!
Old 05-18-14, 11:13 PM
houndawgbp
houndawgbp's Avatar
I just filled up so I'll do this when I'm lower on gas lol
Old 05-21-14, 09:07 AM
ClarkKent
ClarkKent's Avatar
Default Fuel Pump fuse
Make sure you pull the pump fuse before attempting... Yep, pretty simple and quick.
Old 05-25-14, 09:47 AM
Johnny D
Johnny D's Avatar
did you notice a difference in fuel mileage?
Old 05-25-14, 11:44 AM
ClarkKent
ClarkKent's Avatar
Has been going up ever since.
Old 05-25-14, 04:33 PM
Johnny D
Johnny D's Avatar
good to know. Ive been noticing a significant drop in fuel mileage lately and im wonderin if my fuel filter is to blame
Old 05-25-14, 08:11 PM
Titten
Titten's Avatar
OP, you're an awesome individual for taking the time and effort to take and post pics. Thank you!!!
Old 05-27-14, 09:34 PM
ProjektS13
ProjektS13's Avatar
The filter on my gs was so corroded that I had to cut it off, then I used a z32 fuel filter.
Old 03-20-15, 04:17 PM
joewitafro
joewitafro's Avatar
Can you fix the picture links??
Old 03-20-15, 09:10 PM
kene
kene's Avatar
maybe send him a pm... he was on here earlier this month.
Old 03-22-15, 07:29 PM
saiko2j
saiko2j's Avatar
how exactly would i fix them?
Old 03-22-15, 07:40 PM
joewitafro
joewitafro's Avatar
It looks like perhaps you had these photos hosted on facebook? Photos could be uploaded to the forum, if you had updated links of the photos just go to advanced and when you insert a picture you will have the option to enter a URL, or choose a photo from your computer if they are saved there.
Quick Reply: DIY Fuel Filter change/replace
