gs 300 '93 aristo swap
#31
finally its done and ready to go home
we install all vacuum hoses, and the radiator water tank, it was a very good project
like my facebook page pelase
https://www.facebook.com/pages/Ptr-P...2568710?ref=hl
From this
to this
#33
Thank you very much!!! It is great work!!! Sorry for my english (i am from Kazakhstan), but i have one question: TRC is not working at this situation (SWAP) anyway?? Or whether there is a method that earned? Tank you!!!
#34
#35
Hi guys,
Want to share with you that I work in weekend fixing or modified lexus or Toyota car, I do it for hobby so my price always will be much lower than a performance shop, I hope I can work for you some day.
I can do all things that your car or need to be fix or improve performance.
Upgrade turbo set up, exhaust etc.
We weld the ic piping to ovoid air leaks and couples
We perform some pain job
Before:
After:
Just for your reference, for a aristo swap, I charge only for labor 3,500
That include:
Swap engine
Paint engine bay
Extend engine harness
Weld aluminum ic piping and blow off valve flange
Custom Downpipe
Change fuel pump
Install a apex afc II or other piggy back
Electric fan installation
fell free to ask we can negotiated
Also I build custom front face intake manifold for 2JZGE
Supra engines
Check my Facebook page for reference.
Before:
After:
That include:
Swap engine
Paint engine bay
Custom Downpipe
Change fuel pump
Supra engines
#36
could you explain down to detail please ? if everything work well on the lexus before the stock engine harness and ecu take out, when install the aristo engine with a good condition harness you will not have ant problem.
#37
I mean the principle of work of TRC on Aristo and on GS. GS has TRC actuator, TRC accumulator (separate of brakes) and simple brake vacuum, and Aristo has electronic brake vacuum which is responsible at once for TRC and brakes. The principle of work of TRC is connected with brake system. Wanted to learn, whether TRC works for you now? Many thanks for your answer! ! !
#38
